Xbox 360 gurus. wireless Q pls!
Fix or repair daily....
what do i need to connect to my laptop?? my laptop is wireless, i have a wireless router, with a lan cable too. i wanna use the xbox to watch my films from my laptop HD??
Thanks!
Thanks!
or link them both in to your router and share you laptop on there and you should be able to see it on your xbox and access it
or like i do ive got my vids on my external hard drive i just plug that in the usb on the back of the xbox
if you go in to the video settings on your xbox you can link in to your laptop to stream the the films from your laptop to your xbox tells you how to do it if you click on it
Plug in the xbox to the laptop using network cable and then Bridge your incoming Net connection to your Wired network, I did it for about a year as I was too tight to buy a Wireless adaptor!
Adam
Adam
Buy a USB memory stuck and copy any thing you wanna watch onto it. Plug it in the 360 and it will play straight away. Much better than streaming IMO as less to go wrong.
I have a desktop, wired to my router and also the xbox wired cause its close enough at the min.
When i first turned it on and then went onto my desktop, it came up with a link to the xbox automatically. I just clicked off it as i was more interested in playing the xbox.
Is that link for playing movies etc?
then media sharing and check your xbox should have a little green tick next to it if it dosent click on the xbox symboll then click allow.
then on you xbox all you need to do is go to my xbox then video libary then down to your computer name
using wmp click on the litle tab at the bottwm of libery at the top
Cheers i will give that a go later
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
cozzy jeff
14-08-2015 05:46 PM
