Ford parts software?
Create folder c:\microcattemp
Run Install.exe from the setup CD.
Install in folder c:\microcat
Copy mg16.dll, mg32.dll and mg95.vxd to c:\microcat
Move mg16.dll and mg32.dll from the windows system folder to c:\microcattemp
Reboot PC
Run Microcat (with the data CD in the drive) and you’ll get an error as the crack works.
Close the error dialog boxes as instructed.
Run Microcat again and allocate yourself a userid before trying to login.
You’ll get the error everytime you have rebooted your PC.
Reboot PC
Think we may have different versions...
Mines an ISO image that i've mounted on MagicDisc. It's basically the same.
MicroCat is working spot on, it was in Russian, then greek. But i found the english button lol so its all good.
Just ETIS i can't get to load up propperly without needing log on to ford website or it coming up with error saying i've got an older disc than the one i installed it from. even though it's the only 'disc' i've got loaded.
I've tried playing around with the config file and neither way will load up the offline bit of the program
borboyous
22-08-2015 11:17 AM
