EFI Loom Help?
Ford RS ;)
Can Someone help please
Iv got the Whole interior Loom, and Engine Loom Which Is EFI
I was told it was a RS Turbo fiesta loom...
But... It was running on a 1.6 CVH EFI engine ( none turbo )
But the engine had been converted from MFI to EFI and everythink changed
I Looked at the ECU and noticed it wernt OFAB or OFAC
Just wounderin.. on the EFI Loom
If its been runnin say None turbo.. Can the Fiesta RST Loom run None turbo? With a diff ECU ( i.e Non turbo )
And Is it just a matter of Finding a OFAB or OFAC ECU and PLuggin it into my Current EFI Loom and i can run it on my Turbo engine?
If i knew what car the loom come out of i would of told you.. but the car was a conversion, and they put the whole loom in when they did the conversion. soo not much help there.. I was told it was a Fiesta RS turbo loom..
but im unsure if its now just a mean of Pluggin the OFAB or OFAC Ecu into it and away i go??
Help please!!
Help please!!
if its got a standard efi non turbo ecu init then ul have to source the ofac ecu as this plugs straitgh in ucan convert the loom to run an ofab ecu but ul have to source the specific map sensor but even harder to get hold of is the map sensor suppressor ,my advice source an ofab ecu and plug in and away u go ,also if its a non turbo efi loom it wont have the boost solenoid wires ,u can wire these into it or just fit a bleed valve.
muz
30-09-2015 08:29 AM
