constant 10 volts on side lights
I have found that the front and rear side lights of my g/fs mini have a constant 10 volts going to them.
This is increased to 12 when you turn the switch.
The 10V is not enough to quite light the bulb but if you leave the car for a few days then it will not start (but does straight away when you rjump start it) and im guessing this is the fault that is draining the power over a period of time.
I suspected the indicator stalk as that would be common to all lights but this looks more like it controls a relay and even with the stalk disconnected there is still the 10V at the bulb.
There are 2 50A fuses that appear to each fuse the lights for one side of the car.
With both of these removed it droppes the voltage to around 5V.
Does anyone know if there are some relays some where that control the lights? and if so where i could find them.
Or any other thoughts on what may be causing it.
my mates did this after he had fitted led sidelight bulbs,only noticed at night as they was lit very very dimly when it was all locked up on the drive . put standard bulbs back in problem solved.
have you changed any bulbs at all?
put the other bulbs back in and they dont light up but when i checked the voltage on the plug there is still 10V
guessing that is still drawing a bit off the battery over night
Dr. Ickxs
15-09-2015 10:15 PM
