work shop manual for focus rs or zetec engine.
as above does any 1 sell a work shop manual or in depth book on the rs or a zetec engine. As the Haynes manual is not enough info or in depth enough.
not much use to you as proberly doesnt go into enough deoth but fast ford did a bottom end rebuild of a zetec and a guide to fitting cams
will find the issue numbers if its any use to you
