harddrive help
Old Jan 2, 2005 | 01:31 AM
boost mad's Avatar
boost mad
Default harddrive help
i have just got as 200gb seagate harddrive to replace a 30gb. the bios can detect the drive as a 200gb and windows installs the drive, but it doesnt show up in my computer!!! y is this. im running windows xp and i have a fair upto date pc. this is realy getting to me now so please help
Old Jan 2, 2005 | 01:47 AM
luke89's Avatar
luke89
Team HOTHOT!
i have just instaled a 200 bg hdd to my comp wat are u running it as a slave ? if so did u chage the thing on it to slave ?
*edit*
https://passionford.com/forum/viewtopic.php?t=88752
my post that should have all the info in ya need if not i dont no
Old Jan 2, 2005 | 01:48 AM
boost mad's Avatar
boost mad
it willl be as slave yep. but its on cable select
Old Jan 2, 2005 | 02:09 AM
BlueSmoke's Avatar
BlueSmoke
PassionFord's crazy fool!
I think it's just a matter of your jumper settings on the back of the drive. Set it to slave on the drive itself and make sure your cable reflects this. Hope that helps
Old Jan 2, 2005 | 03:25 AM
SS1's Avatar
SS1
how much you pay for the 200 hd please and where from
hope it was not maplin or pc world
Old Jan 2, 2005 | 09:26 AM
Jamz's Avatar
Jamz
You need to create and format a partition in XP using Disk Management (right click My Computer->Manage or via Control Panel)
Old Jan 2, 2005 | 10:09 AM
DanRSturbo's Avatar
DanRSturbo
Right, has this hard drive just been put in as a second drive ? In which case, as said, you will need to create a paetition and format the drive. Start -> Settings -> Control Panel -> Adminsitritive Controls -> Computer Management -> Disk Management, there you should see the drive and can create a partition and format it
Old Jan 2, 2005 | 11:30 AM
boost mad's Avatar
boost mad
thanx for the help. and no it wasnt bought from maplin etc, it was from overclockers.co.uk1 dotn no howe much it was as it was a birthday prezzie. its a seagate drive so it is branded
Old Jan 2, 2005 | 11:32 AM
boost mad's Avatar
boost mad
it does see it in disk management but only as 121gb
Old Jan 2, 2005 | 11:46 AM
luke89's Avatar
luke89
Team HOTHOT!
thats showing very low for a 200gb it normaly shows a little lower as when its caculated it is rounded up or somehting but mine shows 186 gb so yours should be around that mark sorry cant help on sorting it tho
Old Jan 2, 2005 | 11:47 AM
boost mad's Avatar
boost mad
i have just been told that win xp ( the older versions ) didnt support larger harddrives.... and to get a patch from the windows website!!! so i gona have a little loooky. thanx again for the help
Madbradz
Jan 25, 2010 07:50 PM
Zetecfiesta
Nov 29, 2007 11:34 AM
