mobile cutting solutions
other than a large petrol driven circular saw, what car battery/own battery powered tools exist that can cut through chain/ wheel clamps etc??
Is there any small cutters that can go through such hardened steel applications that are small enough to keep in car? Most petrol driven saws ive seen are big and cumbersome being designed for other purposes.
Any ideas?
Any ideas?
used to use thease at work seen them go through thick steel cable not sure how they would cope with hardened steel tho
http://www.cembre.com/asp/E_Prodotti...3=8&idlingua=2
Criminal damage to a Private clamp,, If they can find it, or get you on Watermarked CCTV.
But I would guess it's for WarrenP's own personal clamp in case he looses the key..
http://www.toolstop.co.uk/ryobi-cag1...er-naked-p4354
Plus these;
http://www.toolstop.co.uk/ryobi-bcp1...charger-p10233
how about these . as we had some with us last night when we fort we had to cut a clamp of
http://www.screwfix.com/prods/60600/...tters-762mm-30
Just a standard adbrasive metal cutting disc. Personally I prefer the extra thin discs designed for cutting Stainless Steel over the standard thicker ones.
If you can access ok the chain then swedish bolt croppers are quickest and cleanest, the set I used were designed for cutting 1" hardened bolts that hold down raliway parts on some track points so laugh at chain, they are extendable to 6 feet for leverage., but reduce down to 3 1/2 feet or so, bloody pricey though.
