snapped head bolt, any suggestions?
as above, taken me cab off road for winter an thought id give it a bit of love, taken the head off for some porting an big valves but snapped a bolt in the process, ive tried using one of them reverse thread taper stud remover but didnt wanna force it too much, does anyone have any suggestions on wot to do as i cant move the at the moment an dont really wanna take the bottom end out if i dont need to
any help much appreciated
Needs serious heating for the best chance of removing broken bit, although drilling out as far as you dare with ever larger bits, with patience can do it as the remains of the bolt get so thin you can collapse them in with a old screwdriver etc, messy and long winded but works.
The only easy out I would use is the snap on square taper spiral.
You'll need the oxy bottles to get any sort of heat into it weldin a nut on os a good idea but do doubt if u could get enough penetration through such a small area , bottles and an easyout sounds ur best bet . good luck buddy
This is probably the wrong spelling and i cant remember who makes it but there is a penertrating oil rost off ice that is brilliant, i've removed many a broken seized in stud/bolt with it. If you do decide to drill it i would highly recomend using left handed drill bits as they can somtimes remove bolts when they catch at the bottom of the bolt.
