Stainless exhaust TIG welding question ?
I had a try of a TIG welder this week on some stainless tubing, it was only a quick try and with no purge gas on the inside of the pipe but the welds were much nicer with no filler rod.
If I use just fused welds with no filler rod and purge the pipes with argon will it be strong enough for exhaust manifolds or will it lead to cracks ?
Thanks for any info.
Mark
Mark
The the weld I did hardly pulled in at all as there was next to no gap between the pipes, I was hoping it would be strong enough to save me having to smooth all the welds down so they could not be seen
Any tips for TIG welding stainless ?
I've got a nice new TIG at work but I'm still waiting for the argon to show up before I can practice.
cheers
Mark
cheers
Mark
Make sure you use pureshield argon, and tape up both ends of the pipe, put the purge pipe one end and put a pen tip hole the other, switch the purge on and put your tongue near the small hole to feel the argon.
The inside of the stainless pipe I welded with the filler rod but with no purge gas was not very nice at all, lumpy bits stuck out that will ruin the gas flow
Mark
Run the purge at about 5 to 8 litre"s a min on your flow meter
If you got some short pieces of pipe try it out and see what you think , always make sure your filler wire is clean and not contaminated , just like the pipe your about to weld .
just keep practising mate until you are happy , if you are going to back purge make sure theres a good amount of argon being fed into the tube when welding as there will still be spikes if theres not enough gas. i personally wouldnt dress back any of the welds as your going to lose strenght as you cant judge how much weld/pipe your taking away plus i think if you take your time you cant beat nice tig welding
cheers paul
C.R.E.A.M.
lets see some pics of decent tig welding eh lads,i have old school bmx's from the early to later 1980's and they are chromoloy 4130 tigged and the welds are very nice,from a early age i liked my welding done right and yeah you can't beat tig .
mark have you still got yer v8 escort cos ??
Some nice welds here, nothing to do with me though !
http://www.yellowbullet.com/forum/sh...28&postcount=4
http://www.jalopyjournal.com/forum/s...d.php?t=299587
Mark
CrOwSoN15
10-09-2015 07:33 PM
andrewmctiernan
08-09-2015 03:05 PM
Adam Graham
06-09-2015 06:04 AM
