Fitting a ST170 engine..
Old Dec 13, 2009 | 12:57 PM
JayCC's Avatar
JayCC
Default Fitting a ST170 engine..
.. Into a mk3 Fiesta. Is this straight forward? The bay has been altered to fit a 2ltr zetec (the mount) and basically just wondered what else would need altering? I'm assuming a different set of driveshafts/manifold?
Also, whats needed to fit the gearbox? Is there anything that needs modifying at all?
Old Dec 13, 2009 | 01:23 PM
~nomad~'s Avatar
~nomad~
Presuming the 2ltr in it now is a silvertop, the mount will be a bit different, not sure if you can make something up that will fit the early 2ltr mount. The gearbox mounts completely different to a cvh / zetec fiesta gearbox, its mounted to the innerwing on a st170 rather than on a cradle, will need a fair bit of work. You will also need custom driveshafts, you will need to sort the cable shift fitment, and will have to run aftermarket management as using the st170 stuff will be very tricky, as its quite intergrated into the car.
All that said, it has been done before.
Old Dec 13, 2009 | 02:32 PM
JayCC's Avatar
JayCC
Oh.. actually a fair bit of work then! I'm assuming there are probably a million easier options..
Old Dec 13, 2009 | 02:47 PM
Oranoco's Avatar
Oranoco
In short, not really. We are currently putting an ST170 into a Mk6 Escort GTi and another into a Mk2 Fiesta The Escort is proving a smidge awkward as the air conditioning is wanting to be retained
Old Dec 13, 2009 | 02:52 PM
are you fitting the whole engine complete ie inlet manifold exhaust manifold. Will you be using the original ecu and wiring.
Old Dec 13, 2009 | 11:31 PM
~nomad~'s Avatar
~nomad~
he answer in both cases is no they are not, both on throttle bodies and aftermarket management iirc.
Oranoco, need someone else to want one, another st170 coming in next week lol
Old Dec 14, 2009 | 09:40 AM
KW-rscos's Avatar
KW-rscos
Out of interest, how much? I wouldnt mind one in my mk5b Escort.
Old Dec 14, 2009 | 11:46 AM
Oranoco's Avatar
Oranoco
Cheers Nomad lol. Yes both are/will be using throttle bodies and aftermarket engine management.
The gearbox is cable shift and in both cars we are retaining the IB5/BC boxes.
Old Dec 14, 2009 | 12:18 PM
dalsy70's Avatar
dalsy70
Ive fitted the St170 into my Mk3 Fiesta, just had to modify the engine mount as the hole pitch is different from the silvertop zetec, Also had to add another idler pulley so the water pump could turn the correct way, and have the alternator fitted to the front of the engine
Also need to modify the alternator bracket to give clearance for the water pump, and the bottom radiator hose needs modifying
Gearbox wise, I use a BC box albeit Quaife, and use twin 45 carbs and after market engine management
heres the pic of the engine with the modified engine mount, and pulley that I made
if you want to buy an engine mount already done, Simon Smail at SITECH Racing will do you one, and theres a company now doing the pulley kit, think its RACELINE, they do all the stuff for the Caterhams etc....
Hope that helps a wee bit
Old Dec 14, 2009 | 12:33 PM
mark_24v_wiring's Avatar
mark_24v_wiring
What alternator bracket is that one as i could do with one of those
Old Dec 14, 2009 | 01:48 PM
~nomad~'s Avatar
~nomad~
normally between 350-550 mate, depending on milage etc.
Old Dec 17, 2009 | 01:16 AM
JayCC's Avatar
JayCC
Hmm, Ok guys.. So its not as difficult as first though. Dalsy, I think you should take it upon yourself to tell me exactly what I'd need!!
Nomad, can you PM me when you have an idea on pricing etc? I'm now feeling the need for some proper fun^^
Edit : I'll PM both of you as I doubt you'll see this topic in the near future^^
Old Dec 17, 2009 | 05:04 PM
crazycage's Avatar
crazycage
it easy i did this years ago ,you just need to mod the engine mount and make a pulley for the water pump and trim a little off the fiesta alternator bracket .
162
Dec 25, 2019 09:43 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
Palethorpe01
15
Aug 18, 2015 06:09 AM
track.focus'd
Aug 12, 2015 05:53 PM
