Any electrician in??? lighting question
I have 4 old downlights here, with two way switching and a dimmer, when the neutral is connected I get no live at the lights but when the neutral is disconnected I get a live. Cant get them to work, I thought maybe broken neutral but the cable tests out fine and the other lights on the circuit work. Help!!!
Description is too vague.
There either is a live or isnt. It would have no relevance to there being a neutral there or not, or if its connected.
Test live to earth with a multimeter to prove there is a live conductor. This will at least prove the light switch is working.
Just how exactly are you determining if there is a live or not ?
The dimmer is the most likely suspect, swop it for a normal 2 way switch or try the dimmer on another 2 way circuit if you have one.
Where are you disconnecting the neutral?
What colour cable are you getting the live on, when there is one?
More info required.
More info required.
Dr. Ickxs
15-09-2015 10:15 PM
andrewmctiernan
08-09-2015 03:05 PM
