i've got a problem (any idea's)
i've got an st200 and it's got a few problems wicth im not sure
where to go next so im all up for any idea's if you could help that would be
great.so it keeps burning out it starter motor and it managed it in 3weeks
and all my lights are pulsing and my stereo also turns off when the lights
are on but is fine when their not. i've put a new alternator and the
alternator wiring loom on it. and the battery is fine so any idea's.
cheers gaz
cheers gaz
Over cooking st200 electrics
Hi Gaz. Did the big problems start after the new alternator was fitted? If so it might be the wrong type. I had a similar problem, lights pulsing and boiling battery. The alternator for the st200 has a different regulater setup. I ordered a new one direct from a ford dealer and no problems since. I know it is cheaper from a scrappy but some times more expensive is better. Hope this helps.
Ron
Ron
