who has a T4 turbo? help needed
Old 06-12-2009, 05:45 PM
B13 JUS
B13 JUS's Avatar
Default who has a T4 turbo? help needed
i have a little problem with my t4 turbo on my car.
when it come back from msd there was a problem with the turbo and boost. it would'nt boost any more that 30psi (even with the pipe off the turbo).
its a brand new -31 they fitted for me.
i have had it looked at by vince @ cr turbos and he could'nt find anything wrong. he did clean a couple of the surfaces so the where 100% flat.
i've tried the turbo again and it still won't boost any more than 30psi.
so does anyone have a t4 turbo with an enlarged wastegate penny to try my actuator to see what boost it will produce on another t4?
i will cover all costs on postage both ways
Old 06-12-2009, 05:50 PM
t4 and greys
cosworth gimp
t4 and greys's Avatar
why not just try a -34 actuator instead ???
Old 06-12-2009, 05:54 PM
scoooby slayer
scoooby slayer's Avatar
i really dont understand this mate it held 2.2 bar all day long on my car with the original actuator on aswell.
Old 06-12-2009, 06:02 PM
mechanic28
mechanic28's Avatar
maybe the spec of your engine is holding back the boost?think mine holds 32psi
Old 06-12-2009, 06:03 PM
mechanic28
mechanic28's Avatar
but i have always wondered why a -31 is on mine as well rather then a -34?
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Exhaust man enough?
Old 06-12-2009, 06:10 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
i've got a -34 if u wana try it.......
Old 06-12-2009, 06:11 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Mine has a -31 on it but is still on a safe map only boosting 24psi till i get it live mapped.
Steve
Old 06-12-2009, 06:12 PM
B13 JUS
B13 JUS's Avatar
i have and it boost's over 40psi but msd told me should boost 40-45psi with there -31
pete mcrash
....just cos its got a bigger number on it doesnt mean its better.......
Old 06-12-2009, 06:13 PM
mechanic28
mechanic28's Avatar
i know that,but it would make it easier for the boost control to hold more boost!
Old 06-12-2009, 06:14 PM
B13 JUS
B13 JUS's Avatar
i have one mate and it boosts more but they told me there's something wrong with my turbo
Old 06-12-2009, 06:15 PM
B13 JUS
B13 JUS's Avatar
Exhaust man enough?
i believe so. 3" all the way through
Old 06-12-2009, 06:18 PM
pee vee
pee vee's Avatar
just lock the wastegate shut somehow or other.. if it still wont go above 2bar then there its not the actuator...
Old 06-12-2009, 06:27 PM
B13 JUS
B13 JUS's Avatar
that must have been a -34 because it feels stronger than the -31 but thats knackered now.
Old 06-12-2009, 06:29 PM
B13 JUS
B13 JUS's Avatar
what would do that?
Old 06-12-2009, 06:30 PM
mechanic28
mechanic28's Avatar
head/cams inlet plenum etc
B13 JUS
B13 JUS's Avatar
i can get it to boost more with my -34 but msd told me there's something wrong with my turbo if it won't boost more than 30psi with a -31?
Old 06-12-2009, 06:32 PM
B13 JUS
B13 JUS's Avatar
have you ever tried you car with your turbo pipe removed to see what yours boost's with a -31?
Old 06-12-2009, 06:57 PM
scoooby slayer
if a -34 cures it then get it on and drive it mate. who cares why as long as it works pal
cossiedave
cossiedave's Avatar
my t4 from vince hold 34psi and rest asure if vince says there is nought wrong with your turbo theres nothing wrong with it
Old 06-12-2009, 07:05 PM
dave cos4x4
dave cos4x4's Avatar
how can it be the turbo if it boosts more with the -34 on it.
Old 06-12-2009, 07:07 PM
B13 JUS
B13 JUS's Avatar
i can drive it the way it is but it has been mapped with the air injectors fully open on a -31, stu said its not the best way to have it.
if i put the -34 on it will boost more and its only been mapped upto 30psi so stu told me it will be unsafe to run more.
i am trying to get in sorted for the next mapping session
Old 06-12-2009, 07:10 PM
B13 JUS
B13 JUS's Avatar
no sure mate but stu told me theres a problem and so did james
https://passionford.com/forum/genera...r-produce.html
Old 06-12-2009, 07:11 PM
dave cos4x4
so whats the lowest the -34 can be set too,surely it cannot be more the 30 psi.
B13 JUS
B13 JUS's Avatar
what actuator have you got and how much preload?
Old 06-12-2009, 07:15 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
a -31 is all you need on a t4
-34's are for t34 and the likes
Old 06-12-2009, 07:17 PM
Moonstone Steve.
Enough said......
Steve
mechanic28
mechanic28's Avatar
no mate i have only driven her home so far i presume your cam timing is spot on?
Old 06-12-2009, 07:22 PM
B13 JUS
B13 JUS's Avatar
yeah msd checked it and moved the exhaust cam 1 tooth as it was out
Old 06-12-2009, 07:24 PM
B13 JUS
B13 JUS's Avatar
what boost have you seen a -31 produce on a t4 with a hole of preload?
vince did say my -31 opened a little earlier than a garret -31 but should'nt be a problem
Old 06-12-2009, 07:25 PM
mechanic28
mechanic28's Avatar
what cams you running?what your c/r bud
Old 06-12-2009, 07:31 PM
Turbosystems
Super Moderator
so you don't have a garret -31 you have a mickey mouse one then
-31 refers to a genuine garret one only as does -34 the fact that somecompany has chosen to put -31 on their actuator does not make it a garret -31
we only use genuine garret parts
heinz don't make beans for any one else either
without any pneumatic control pressure on the actuator on a genuine t4 turbine housing with the correct size by passport and penny you will see pressures at peak load over 5 bar
we have of late seen quite a few t4's with the wrong size by pass port and waste gate penny
Old 06-12-2009, 07:39 PM
B13 JUS
B13 JUS's Avatar
bd14 inlet and standard ex cams
standard c/r
Old 06-12-2009, 07:45 PM
B13 JUS
B13 JUS's Avatar
my pass port has been enlarged but vince told me everything measure up fine, as he did clean it up as the edge's where a little rough
what to you me by (without any pneumatic control pressure on the actuator)?
even with my -34 it won't produce 5 bar or boost.
any suggestions tony whats wrong?
Old 06-12-2009, 07:53 PM
Gary F
Gary F's Avatar
Im sure I've heard this story before
Old 06-12-2009, 08:51 PM
Dicko&Vacant
Dicko&Vacant's Avatar
id just buy a brand new genuine garret -31 and try that mate
Old 06-12-2009, 08:55 PM
mechanic28
mechanic28's Avatar
maybe that set up cant shift the air quick enough to boost anymore?
Mind you having said that i am sure stu/james would of told you this!
Old 06-12-2009, 09:04 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Steve
Old 06-12-2009, 09:08 PM
Staffi
Staffi's Avatar
I wondered when you two would start...
Originally Posted by cossie4i
Steve
Bad lads you two are..
Quick Reply: who has a T4 turbo? help needed
