Towing weights!
Old Dec 5, 2009 | 03:40 PM
mechanic28's Avatar
mechanic28
Exclamation Towing weights!
Is there a website that shows what cars can tow by law?want to see if i can tow my cossie on a trailer with my cavalier!just a option i am looking at when i take her for its set up as i am on limited mileage policy
Old Dec 5, 2009 | 03:50 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
http://www.parkers.co.uk/advice/TowingWeightCalc.aspx
goodluck
Old Dec 5, 2009 | 03:52 PM
mechanic28's Avatar
mechanic28
cheers dan!
And like i put in my pm hurry up man so i dont have too lol!
Old Dec 5, 2009 | 04:23 PM
focusv8's Avatar
focusv8
Not a hope, no chance (legally).
Old Dec 5, 2009 | 04:24 PM
mechanic28's Avatar
mechanic28
pants!!!not even if the tralier has brakes?
Old Dec 5, 2009 | 04:33 PM
DazC's Avatar
DazC
You need to look at the train weights on the chassis plate, and then find out how much you Cav weighs fully loaded with you and any passengers sat in it and the trailer fully loaded weighs. Add the weight of the Cav to the trailer and subtract the total off the train weight of the Cav.
Old Dec 5, 2009 | 04:44 PM
alistairolsen's Avatar
alistairolsen
First of all it NEEDS brakes by law if it has the capacity to have a cossie on it. Max unbraked is 750kg gross.
Secondly, the towing limit of a cavalier will likely be around 1300kg. If the maximum autorised mass of the trailer and cossie is less than this fine, but I doubt it.
Finally, if you're on a pst '97 license, then you will struggle to get around the rules, as starting with a 1300kg cossie, even if you found a trailer with an 1800MAM, you would then be over your license limit with the towcar and trailer.
IMHO the biggest common combination you can do is something like a 900kg car on a 400kg trailer with an MAM of 1300kg, behind a mondeo which is a little over 1300kg unladen, and around 2 tonnes MAM, giving a combined MAM of 3300kg.
Old Dec 5, 2009 | 04:45 PM
mechanic28's Avatar
mechanic28
i am on a pre 97 licence bud so can drive 7.5 ton lorries etc!
Old Dec 5, 2009 | 04:47 PM
mechanic28's Avatar
mechanic28
got a feeling tho the cavalier is going to be too light!
Old Dec 5, 2009 | 04:48 PM
Dan@Rapid-Ford
Why don't you buy my Range Rover with LPG conversion then you can hire a trailer to tow the car around to the shows etc anytime
Old Dec 5, 2009 | 04:52 PM
mechanic28's Avatar
mechanic28
i got to many cars already !very kind offer tho dan
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
wowk
Mar 30, 2021 07:49 PM
pabloXR
Sep 21, 2015 12:42 PM
Cos500
Sep 16, 2015 09:50 PM
c14rks
Aug 11, 2015 05:17 PM
