Compomotive MO Offset stamp - where is it ?
Hi Guys, ive bought a set of Comp MO for my Evo but they dont fit on the hub, theres about a 1 cm gap from the 2 faces, it says on the casting face 18x8 but no ET number on it on either side. Any ideas how i can actually find out ?
it is usually stamped on of the spokes, to measure the offset, you need to measure from the back of the hub face to the back of the rim, then minus 4 inch (presuming they are a 8 inch rim) from that figure to give your offset.
when you say there is a 1cm gap from the two faces, what do you actually mean? it wont go over the spiggot?
yea thanks i only checked the 1 alloy it says et then blank, ill check other 3 tomorrow then ta. least i can know then what they fit lol
