Steering rack pipes that go into 2WD rack?
Finished fitting the new rack last night on my 2WD, and on closer inspection one of the 2 pipes (the bottom one) that goes into the rack and is held in by the plate with the bolt isn't a tight fit into the hole???I think this is the return from the rack as it goes into the top of the PAS bottle. I haven't tested it yet as the battery was flat, so i can't see if it leaks, but my question is, is this "normal" ???
Resident Wrestling Legend
the plate secures the pipework, so if it's lose it's going to leak
you can always try and bend it back the other way if it's not going to be stressed out too much and snap off, in which case you need to get a new pipe, or find another pipe with the plate, cut it off and fit it to be doubly sure
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
