processor probs :( **** UPDATED ****
Old Dec 30, 2004 | 08:29 PM
markk's Avatar
markk
Default processor probs :( **** UPDATED ****
ok soi get a pc off my brother who says it keeps switchin itself off after a short while, so i check the processor - same as mine, so we take the cpu out of mine in an even to try an eliminate the problem wether it be cpu or motherboard, alls going well, refited switch on , all my com does it spins up for approx 3 secs then switches back off i think , cpu funked
swapped my cpu back in , go and restart , exactly the same, so is the fault that that processor is fooking motherboards ?
is this possible ??
i think my board must now be fooked and i only bought it about 9 month ago
had to resort to the fookin laptop
any help please ???
mark
Old Dec 30, 2004 | 08:36 PM
What kind of processor is it? Athlon?
Old Dec 30, 2004 | 08:51 PM
markk's Avatar
markk
yeh amd athlon xp2000 - somat like 1.6ghz ???
FOOKED
Old Dec 30, 2004 | 08:52 PM
Dilly's Avatar
Dilly
try resetting the CMOS with the jumper, then reboot
Old Dec 30, 2004 | 09:02 PM
Stu.H's Avatar
Stu.H
faulty motherboard mate.
do u usually reset the CMOS when the pc is powered up then?
Old Dec 30, 2004 | 09:09 PM
Dilly's Avatar
Dilly
nope, when it's off
Old Dec 30, 2004 | 09:12 PM
Before you do that, you might want to check that the fan is making good contact with the CPU. Scrape the heatsink compound off the base of the fan and put a new heatsink pad on with some heatsink paste....
Worth a try....the contact area on an Athlon CPU is very small and I've seen similar things before
Old Dec 30, 2004 | 09:16 PM
markk's Avatar
markk
cleared cmos - no difference - so its fooked the board, so the processor and theboard must be fooked now , as before i fitted this cpu the computer worked fine
Old Dec 30, 2004 | 09:43 PM
Ian M's Avatar
Ian M
dont let anyone tell ya meddling is not an art form !!
Old Dec 30, 2004 | 10:20 PM
markk's Avatar
markk
***********update ***********
the problem with the non start was core temp over heat !!!! top geezer
but now it will only start to bios, finds hard drives and all floppys , but wont go to xp operating systems,
just keeps giving options for safe mode, last known good setting , start normally etc etc
and a count down, non of these options do anything, the comp just freezes once the timer stops
more help ???
cheers dudes
Old Dec 30, 2004 | 10:34 PM
NUTS RuS's Avatar
NUTS RuS
What drive is it trying to boot up on first ?
Old Dec 30, 2004 | 10:41 PM
Stu.H's Avatar
Stu.H
that isnt the bios, thats the operating system of the hard drive tring to find something to boot from
u need a reinstall tbh mate
u far?
Old Dec 30, 2004 | 10:52 PM
markk's Avatar
markk
it was trying to boot the hard drive 1st but ive changed it to disc to try and repair the problem , i think its struggling to find th o/s ???
Old Dec 30, 2004 | 11:00 PM
Stu.H's Avatar
Stu.H
Well if u playin about with boot priorities, then it will cause problems.
Old Dec 30, 2004 | 11:35 PM
markk's Avatar
markk
ive only tried changing boot sequence to try and sort this lack of booting problem, it wont even boot from cd ,
ive had enough now for tonight m], fookin ell i only took a fookin processor out , its notlike ive never done it before
cheers guys
Old Dec 30, 2004 | 11:56 PM
M Brian's Avatar
M Brian
my PCs being running real crap and doing same kinda thing but mine has been lasting 5 hours or so.
ive taken the case off and its better.
ive still got quite high CPU temps on average now 50ish i think and PC is noisey.
have i got similar problems? as mine is xp2400 amd thingy similar
Old Dec 31, 2004 | 11:11 AM
Dave Henshall's Avatar
Dave Henshall
this sounds very much like the main pc powersupply - i had one do the same - ended up buying a new 10 quid power supply for the case from microdirect and all was fine - it would be ok until it tryed to do any work and loaded up the powersupply , so on first startup , it could reboot say 15-20 times if u left it to it before it finally got into windows, then u would launch something that made the cpu work for a few seconds and "click" reboot again.
Old Dec 31, 2004 | 11:15 AM
Daveyboy's Avatar
Daveyboy
i'll second the psu theory. Also seen it myself a few times
Old Dec 31, 2004 | 11:17 AM
Jim Galbally's Avatar
Jim Galbally
should actually run WORSE like that unless youve got your PC crammed in the corner where it cant get any good airflow. as with the case on you have good airflow inside the case... take it off and theres no airflow... the case fans then become useless and you're relying 100% on the CPU fan...
Old Dec 31, 2004 | 11:23 AM
Steve200+'s Avatar
Steve200+
I'm presuming the fan on the PSU's still working... try swapping the ram out.
Old Dec 31, 2004 | 11:52 AM
MikeyXR2i's Avatar
MikeyXR2i
Me Third it too, cos ive had a couple do it.
One i had started kicking out 2 much juice, and fooking the new boards i was connecting up, it was woudl start for a few secs then shut off.
TPM961
Jan 15, 2018 10:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
pabloXR
Sep 21, 2015 12:42 PM
gcfcos
88
Sep 15, 2015 03:48 PM
