Waste Spark Loom??
Ok, bought this Waste Spark Loom from Motorsport Developments, everythings fine with the part but im just stuck on where the 2 white wires go to in the picture below.
![](http://i219.photobucket.com/albums/cc281/coleyst200/001-1.jpg)
I summise these go to the phase sensor in which case should this not be a plug? Can anyone shed any light on the matter please?
Thanks
Thanks
1st to 200 without NOS
Thanks
Thanks
thanks mate thats a big help . there was no paper work with the loom the driver did so all good there . the paper work dose say that on a 3dr i wont have to mod the rev counter but i do no a lad thats had to mod his is it just some that do need it doning or wot
I've fitted a Defi Rev counter to mine and found it didn't work and read half the actual RPM reading after fitting the wasted spark kit, having abit of a stab in the dark I took the signal wire from Pin 21 and it worked perfectly I also changed the SECS gauge signal wire from Pin 25 to Pin 21 and that then worked perfectly too.
See my post on the SECS gauge:
https://passionford.com/forum/ford-s...ml#post4487186
I've never tried it on a original Rev counter but it maybe worth tring changing the signal wire to Pin 21 and see what happens, can't do it any harm.
Rich
Rich
DixieTheKid
11
06-06-2020 11:20 AM
155lee
24-10-2015 11:11 AM
muz
30-09-2015 08:29 AM
deathrider666
28-09-2015 06:12 PM
DixieTheKid
14-09-2015 09:04 PM
