wills ring
Old Dec 30, 2004 | 04:40 PM
ricky's Avatar
ricky
Default wills ring
does any one knows what type of head gasket to used with
a wills ring block and who sell the rings
does it come as a package rings +gasket
Old Dec 30, 2004 | 04:48 PM
Billabong's Avatar
Billabong
What engine?
Old Dec 30, 2004 | 04:49 PM
tiny's Avatar
tiny
A groove is cut into the surface ether the head or the block not bowth, and
then wire is inserted into the groove welding wire is used to great effect,
then a conventional type, good quality head gasket can be used, and when
tourqued down gives better sealing qualitys
Old Dec 30, 2004 | 05:05 PM
ricky's Avatar
ricky
sorry folks its a 200 block out of my 4wd
the block as these rings inserted which are gas filled
i now this case i punture a couple of them trying to remove them
and i could hear gas escapeing from them so not shure if
these are wills or coopers any one could sheed a bit more light on this
Old Dec 30, 2004 | 05:11 PM
Billabong's Avatar
Billabong
IIRC the gas filled ones are Wills-type rings - any idea who fitted them? I've not personally heard of anyone using Wills rings on a 200 block, as most (in as far as the ring type sealing method, as most people would opt for a WRC or Cometic type gasket nowadays) are either wire rung (solid wire used), or Coopers ringed (tend to go "jus' like that!"
http://www.yorkshirerallyspares.co.uk/ Click on Ford Parts, and you'll see they list Wills rings / gasket for competition Pinto - they might be able to help?
Old Dec 30, 2004 | 05:17 PM
ricky's Avatar
ricky
no idea who fitted them m8
bought the car 9years ago
with a focked engine {one piston}
well none tuner re-build it 1200miles
engine let go again so got this block sitting around
doing fuck all
Old Dec 30, 2004 | 05:24 PM
RSCAT's Avatar
RSCAT
thought this was gonna be a joke about gay boy will young
biggiejody
Insurance
Sep 2, 2015 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
andy130
29
Aug 12, 2015 05:59 PM
