Anybody got any ideas?
Old 30-12-2004 | 04:35 PM
pee vee's Avatar
pee vee
Default Anybody got any ideas?
my car is makin some funny noises
bout 4K RPM it seems there is a metallicy rattle,
as you go thru the rev range
it starts at 4k rpm, and then goes, and comes back slightly
at bout 5-5500 rpm.
any one got any ideas what this could be??
metallicy rattle type sound
cheers.
Old 30-12-2004 | 04:47 PM
Nath's Avatar
Nath
Sounds like it could be detting from your description. I'd be careful driving it around, also what fuel are you using?
Old 30-12-2004 | 04:51 PM
pee vee's Avatar
pee vee
sorry, forgot to mention,
this is a N/A 2ltr Zetec, using ordinary unleaded fuel..
Old 30-12-2004 | 05:11 PM
pee vee's Avatar
pee vee
is there any way of telling for sure what it is??
what could it be caused by?
underfuelling?
pretty sure the timing is ok, as the engine idles fine, and behaves
perfectly normally, dont seem/feel to be down on power.
any ideas would be great cheers!
Old 30-12-2004 | 05:14 PM
RANJ's Avatar
RANJ
chk ur cambelt hasnt jumped a tooth
Old 30-12-2004 | 05:17 PM
Jim Galbally's Avatar
Jim Galbally
deffo get that looked at mate...
could be pinking, could be contact i the chamber etc. etc.
Old 30-12-2004 | 05:21 PM
pee vee's Avatar
pee vee
cheers guys
will check the timing first off!
then go from there!
Old 30-12-2004 | 06:00 PM
NUTS RuS's Avatar
NUTS RuS
Does it do it in neutral ?
Ie with no load on the engine ??
Old 30-12-2004 | 06:05 PM
pee vee's Avatar
pee vee
no mate, it dont do it in neutral i dont think.
it also dont do it if you load the engine at lower RPMs
just at the 4000 RPM mark.
Old 30-12-2004 | 06:13 PM
NUTS RuS's Avatar
NUTS RuS
top end, bottom end or in the middle of the engine ?
Can you tell ??
Old 30-12-2004 | 06:16 PM
pee vee's Avatar
pee vee
sadly not mate,
only happens when im driving.
thing is.
engine had new rings and bottom end bearings 12,000 miles ago
lol
but this noise has only started very recently, as ive only just noticed it,
and i've often got the window open!
(and No, its not so the chavs can hear the stereo lol )
Old 30-12-2004 | 06:41 PM
NUTS RuS's Avatar
NUTS RuS
That makes it difficult to diagnose then. So you cant tell if the noise is coming from the top or bottom. Ticking will be top, clonking will be bottom
Old 30-12-2004 | 07:35 PM
pee vee's Avatar
pee vee
umm, its kind of between the two i guess. lol
a definite rattle, as if the engine is being really heavily loaded..
its not a clonk, and its not a tapping either lol
so i guess that spells rings!? but they aint that old!
mark94
Ford Mondeo Including ST
10-10-2023 07:52 PM
Brickhouse
14
03-10-2015 08:28 PM
Fezman1
02-10-2015 02:22 PM
Orion_Gav
29-09-2015 05:50 PM
rogerxr3i
13-09-2015 07:56 PM
Quick Reply: Anybody got any ideas?
