What size external wastegate for what bhp?
going to be running external wastegate on the new cosworth engine but there are so many sizes 36/38/44/46mm etc none state what power it's suitable for so how do you work it out? I doubt il be running over 550bhp max.
Thanks marc
Thanks marc
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Depending on space restrictions, go for the biggest you can get in there! The more exhaust gas you can flow away, the more accurate your boost control can be!
Personally depending on the actual end power figure you go for, i'd look at the 38mm as the minimum and go for the 44mm if you're under 550bhp.
I normaly run a 1.2 bar spring set up, Some boost control set up works better than others and this can let you run a softer spring.
Mark
Mark
www.looseboltsmotorsport.com , very good and quick delivery , plus he puts a reduced invoice in so you dont hardly pay any import tax
tial 44mm is £250 all in which is a bargain
cheers paul
cheers paul
id imagine you will have to run best part of 30 to 35 psi on that turbo setup to achieve 550 hp,so you will need the right spring to control the boost properly,good project ,will have a proper nose when its finished as no dobt you will be at one of the brunters thrashes next year
cheers paul
cheers paul
reyland does them for £361 delivered so think for a uk supplier il buy from the uk
Johnny Knoxville
30-09-2015 07:21 AM
