body filler
Puller of the Wrench
Paint bubbles due to rust. Rust in my experience is there simply due to lack of underseal or sealer.
The cavities that hold water in a saff for instance are not sealed well. If salty moisture gets in there it will rot badly like mine did. Every place that has seen grinding or welding is getting black sealler goo sprayed in there.
Professional grade bondo/filler is only as good as the metal it gets put over. I spray rust converter on anything I have repaired as well.
Don't use cheap stuff either.
mk3ste
17-10-2021 10:09 AM
