Ford Radio Mute
Right... well you aint replying quick enough so....
On the back of the stereo you have 2 blocks of connectors.
8 and 7 holes.
1 of them carries the power and the other carries the speaker wires.
In the middle there may be a third block or it may be just a load of pins- the mute is one of these pins
In order to find out which one is the radio mute, you need to earth it - but the safest way is using a test light.
Using your test light just, with the stereo on, just touch the pins in the middle block one at a time.
You'll tell when you've found the mute as the stereo will mute and display phone or mute on the screen.
Connect your mute wire to this pin.
8 and 7 holes.
Daisychain
22-08-2015 08:12 PM
borboyous
22-08-2015 11:17 AM
