Mk4 fiesta zetec s what engines fit??
As in conversions or as direct replacement. Must be a simple conversion.
Does the puma 1.7 fit? Whats involved any help appreciated.
A thought I had was: if the mk6 fiesta comes with the zetec 1.25 1.4 1.6 but also the duratec 2.0, why doesnt the duratec fit? what's the problem as this would be a mint conversion surely?
You need:
Left hand engine mount
3 Plug wiring loom for the mk4
You will also need to extend the throttle cable, a breather pipe from the brake servo and also different connections to the engine on the fuel lines, i suggest you make sure you get this part when you get your engine! you will have to replace these and are available from ford.
The puma airbox and MAF if the engine doesn't have it.
Also the correct ECU to run the puma.
You need:
You need, a set of cams ( shawspeed SS4) , a 4-2-1 Manifold and exhaust,stronger rod bolts and stiffer valve springs and a remap.
You'll wonder what the fuck the point is in fitting a 1.7 then as you'll comfortably be 150bhp with the potential for more if you change the standard airbox and inlet mainifold for TB's
hello mate,
i have done over 40 puma convertions
if you would like me to run through exsactully what you need to do and what parts you need to find yourself feel free to give me a call on 07985266042 and i'll talk you though everything you need to know.
my spelling, grammer and sentance writing is crap so if i put it on here you wouldn't be able to read it anyway.
cheers
cheers
Thanks mike i may well do that. I'm not fussed on looking for power just seems the 1.7 is an easier engine to find. I messed up to as i ment mk5 fiesta not 4 its the triangle headlight 1.
JoeyBoyden
04-01-2024 02:36 PM
