a video of my crash from the ring
Old 06-11-2009, 03:42 PM
  #42
Chip
*** Sierra RS Custard ***
Chip's Avatar
John, I dont really find a helmet very restrictive in terms of vision TBH, although maybe im just too used to them as ive always had bikes until recently.
Old 06-11-2009, 03:45 PM
  #43
Dan F
Dan F's Avatar
You can keep an eye out on other cars while wearing a lid its easy
Use the wing mirrors and interior mirrors
Old 06-11-2009, 03:58 PM
  #46
Mr RS500
Mr RS500's Avatar
Originally Posted by Chip
He didnt lift mate, if you watch it again and listen carefully you can hear the engine note change as its swinging about.
The reason for the crash was a loose rear beam bolt, he never stood a chance at catching it even though he didnt everything right IMHO, as the beam was moving on the car.
When I drove Ian's car the day before I was convinced that something was loose at the back but I think cause he had been driving it as it became loose he hadnt noticed the change as it was gradual, we even jacked it up in the hotel car park to have a quick look at it after I said I thought something was loose but we were only on a little jack and couldnt really get it up high enough to look at properly so didnt manage to find it, he only found out about it when he was next working on the car.
With regards to the barrier, he was quite lucky he didnt get charged more, it actually moved one of the posts back a litle, but I covered up the witness mark before the guy from the ring arrived
I'll see if I have got the picture of the barrier that I took, as Ian mentions it was clearly dented.
I bet they still havent replaced it though they hardly ever do it seems, they charge you for the slightest impact and then dont bother to replace it till someone has a bigger crash there, they charged me to replace barrier I hit and yet 18 months later I could still see the mark I had caused, bet it will be the same if we go back this year and look at ians barrier, lol
So what bolt was loose then ??
Old 06-11-2009, 04:03 PM
  #47
Chip
Chip's Avatar
IIRC it was the main beam mounting bolt mate, but Ian can confirm or deny that, we'd put the jack under that bit of the beam to put it up in the air if I remember right, so in doing so would have stopped outselves getting access to that one annoyingly.
We jacked it up, gave it a good wiggle on the wheel to see if anything wanted to move, and it didnt, so tried the other side and it didnt either, so we both assumed I was wrong about something being loose.
Guess next time I get a feeling something is loose on someone elses car I will bother to check every single nut and bolt in case im right again
Old 06-11-2009, 04:04 PM
  #48
Dan F
Dan F's Avatar
Originally Posted by S1 JOHN S1
A full helmet,And it doesn't impede your vision one bit???
That's all i am saying dan,
Each to there own i wouldn't wear one
Im just so used to wearing one that it doesnt impede my vision
Yeah each to there own I would wear one
Old 06-11-2009, 04:05 PM
  #49
Chip
Chip's Avatar
As no one else really wears one at the ring, I think I would feel a bit "try hard" if I wore one, but it probably is a good idea from a safety point of view.
Old 06-11-2009, 04:09 PM
  #50
COCHYN
COCHYN's Avatar
Well that's clearly common sense. If people want to be naiive enough to avoid wearing safety gear on the most dangerous road surface in Europe because its seen as some stupid trend, then be it on their heads. Personally, I'd be compelled to wear one driving anything with the capability of doing over a ton on surfaces resembling a roller coaster.
Old 06-11-2009, 04:10 PM
  #51
Chip
Chip's Avatar
Originally Posted by COCHYN
Well that's clearly common sense. If people want to be naiive enough to avoid wearing safety gear on the most dangerous road surface in Europe, then be it on their heads. Personally, I'd be compelled to wear one driving anything with the capability of doing over a ton.
I often do more than that on my way into work, I reckon Id get some funny looks turning up at a clients in a suit and a skidlid
You're totally correct about it being safer though im sure, although I would argue that really you need a neck collar too, I never wear a crashhelmet without one these days, as the crash helmet alone can really increase the chance of nasty whiplash, I bet me and Ian would have both been hurting far more in the crash we had if we were wearing a lid and no neck brace than with nothing.
Old 06-11-2009, 04:11 PM
  #52
COCHYN
COCHYN's Avatar
*Edited above
Aye, but nothing in this country resembles the Ring does it
Old 06-11-2009, 04:24 PM
  #53
Chip
Chip's Avatar
Ah, didnt see the edit about roller coaster, yes I see you point, on track it makes sense to wear safety gear, but weirdly at the ring its just not common practice, although some people do it.
Old 06-11-2009, 04:30 PM
  #54
dingla rs
dingla rs's Avatar
lmao fort ya had a fag hangin out ya gob when got outa car for one min,lose bolt humm luk like it got away on u's to me no wounder it going 4x4 now ,lovely car tho ,sore it spin at rsoc day
Old 06-11-2009, 04:33 PM
  #55
Chip
Chip's Avatar
Dingla, it definately "got away" but if the bolt was loose at that point then any movement in the rear beam would make catching it a lot harder, Ian seemed to be putting the right sort of inputs in but not getting the right results.
Old 06-11-2009, 04:36 PM
  #56
COCHYN
COCHYN's Avatar
50/50 chance, although he lost it a little you know it could have been worse at those speeds. Never mind though, turned out to be a possitive move on his part, finally went for the RS kit he secretly wanted anyway.
And he gets a rare Nurburgring Bill to frame Dude!
Old 06-11-2009, 04:37 PM
  #57
dingla rs
dingla rs's Avatar
yer he put lota work into it ,least it didnt do much damage looks better with rs quarters on,is the beam not solid mounted ?
Old 06-11-2009, 04:41 PM
  #58
f6cus
f6cus's Avatar
it was one of the adjusters on the arm that had come loose mate
Old 06-11-2009, 04:43 PM
  #59
COCHYN
COCHYN's Avatar
You'll know to put more cable ties on next time Mr. Gerrard!
Old 06-11-2009, 04:44 PM
  #60
f6cus
f6cus's Avatar
yer the beams solid mounted mate i was having trouble with variouse parts vibrating them self loose the exhaust manifolid being one of them i sorted that out by using nord locks you need a breaker bar to crack them bastards off
Old 06-11-2009, 05:00 PM
  #61
Mr RS500
Mr RS500's Avatar
Now that makes sence because i was just about to reply that any loose bolt on a rear beam wont cause any serious problems , a bolt missing yes , but not a loose one
Having a rose joint loose will cause problems tho
very suprised it didnt snap tho
Old 06-11-2009, 05:02 PM
  #62
f6cus
f6cus's Avatar
was very luck it didnt drop right of the car paul there wernt many threads left holding it when i found it am using nord locks on everythink now just to make sure
Old 06-11-2009, 05:20 PM
  #63
Mr RS500
Mr RS500's Avatar
Glad there wasnt to much damage mate
This has always been a problem with Rose joints , they are a great thing until they let you down
A bit like women
Old 06-11-2009, 05:22 PM
  #64
COCHYN
COCHYN's Avatar
Bit too much info there Paul
Old 06-11-2009, 05:27 PM
  #65
f6cus
f6cus's Avatar
A bit like women
Old 06-11-2009, 05:54 PM
  #66
forestfighter
MK2 Fez Wanted
forestfighter's Avatar
it was 635 euro they charged for 2 lengths of barrier lik
Robbing bastards... This is what puts me off going to the ring...
Old 07-11-2009, 08:10 PM
  #67
fiend
fiend's Avatar
Woah there mate, you've read too much into that, I drove the car and said I felt something was loose, Ian didnt think it felt any different to normal though when he drove it, as is often the case when something works loose and you are driving the car its such a gradual change that you dont notice it when you are driving.
We jacked it up and checked what we could with the limited resources we had available, and everything we pulled and push on felt normal so we both just assumed I was mistaken.
As the only thing he had telling him it was loose, was some bloke who had never driven the car before and he could find no evidence to support what I was saying and it still felt ok to him, I dont think he had any reason to believe me.
No good bitching at him about how he should have done something different as im sure he is aware of that now, but at the time he had no reason to believe there was anything up with it, so didnt know he was taking a risk!
Oh my bad. I read it as though you both knew there was a problem, but went out anyway.
Sounds like you guys came off lightly and it could of been alot more worse!
Old 07-11-2009, 10:17 PM
  #68
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
agreed mate. Never used to notice it when I raced, and as I have mine at home from when i did race, I'd just take it along as its there, would seem silly not to.
Old 08-11-2009, 09:23 AM
  #69
escort700bhp
escort700bhp's Avatar
what one?
Old 08-11-2009, 02:57 PM
  #70
Graham88
Graham88's Avatar
Unlucky, was very close to saving it. Can I ask though did you brake on the final spin? Just the way it suddenly spun out despite it looking like you'd saved it makes it look so.
Unlucky on the Bill, I'd have been tempted just to drive off and see if I could get away with it, or do they have cameras and marshals everywhere?
Old 08-11-2009, 03:26 PM
  #71
t4 and greys
cosworth gimp
t4 and greys's Avatar
quite clearly shows on the video he did
lucky and unlucky at the same time .... i imagine the shorter wheelbase doesnt help with correcting it when it steps out
can i ask if you have a quick rack on the focus ???? may of helped if you had
just proves why its manly owning a 2wd and why they need utmost respect whilst driving
Old 08-11-2009, 03:29 PM
  #72
Graham88
Graham88's Avatar
Yeah now you've said it I can see it now, was literally just a stab but shows much difference it makes
The quick rack question has already been asked
Old 08-11-2009, 04:30 PM
  #73
f6cus
f6cus's Avatar
yer i did brake at the last minute but if you look at the video we were fastly approaching the turning point for the next corner which if it was still unsettled on the corner the crash could of been a lot worse
Old 08-11-2009, 04:54 PM
  #74
focus st2
focus st2's Avatar
unlucky fella. you nearly saved it.
cant believe they charged you for damage to the barrier
Old 08-11-2009, 04:59 PM
  #75
Ollie.
Ollie.'s Avatar
You'd have saved that if you didnt brake. Unlucky mate.
Old 08-11-2009, 05:09 PM
  #76
AJC
PassionFord Gold Member (Male)
AJC's Avatar
nearly safe
Old 08-11-2009, 11:09 PM
  #77
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
not been on for two weeks so only just got SIB'S pm cheers mate
Thought you'd like to relive the moment
Here's the bill for those wondering about the costs, as you can see they don't just charge for the small amount of barrier, but all associated costs too:
And to add to the pleasure of the bill, Ian had this to fix too:
So moral of the story is don't crash at the Ring
At least the car's looking better than ever, and you being the sound guy that you are can have a laugh about it now, and keep us entertained too
Old 09-11-2009, 01:29 AM
  #78
Graham88
Graham88's Avatar
Ouch looks like it rippled that rear quarter!
Old 09-11-2009, 01:32 AM
  #79
Chip
Chip's Avatar
Rear quarter is now a far sexier focus RS one, Ian had already bought them and was intending to change anyway, so at least it bent the right thing, lol
deathrider666
28-09-2015 06:12 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: a video of my crash from the ring
