im part of the off the road club
Focus WRC
check out my thread in the technical section, im now part of the my RST is off the road club!
Rad was running dry and has caused a metal press stud thingy to pop off one of the pulleys tht sits below the first cam pulley so water is pissing out everwhere. Either the stud can be pressed back in or a newn and the engine will work again or it will have warped it, this happened to anybody else?
Focus WRC
I honestly dont know man, its a round piece of metal looks like a big button that sits on the end of a cam pulley?
If this has popped off and the water ran dry and smoke coming from my engine bay does this mean the engine is goosed or could it be ok and this just need putting back in and the engine filling up with water?????
cheers reply asap
Focus WRC
have just googled cvh core plug and thats exactly what it is yes, does it hold the water in the cvh head or something? and will my engine be ruined with it cutting out cause it was too hot or is there a chance it might be ok?
Focus WRC
Well there is no oil/water mixing together and the head gasket was only replaced last year. Is there no chance that this core plug could be put back on and the engine fire up again?
Focus WRC
I was doing a steady 60 on the motorway because i knew it was i didnt even go into boost from the moment i started the car to when that happened.
So does this happen with these plugs popping out? Also is it best to put a new plug in and try it with a new plug or is it ok to just use the orig one and knock it back in, if i knock it back in will it be in tight enough or does it need to be specially pressed into the hole?
