Plumbers?? Immersion heater stat test !!Where's Tiff?
Old 22-10-2009, 05:36 PM
kjc300
kjc300's Avatar
Default Plumbers?? Immersion heater stat test !!Where's Tiff?
Hot water went off a couple of weeks ago, new stat fitted. Hot water back.
Hot water gone off again, just changed element - not working!!
checked with meter, element has 19 ohms (which is good for a 3kw so I've found) The old element is also the same.
240v through the stat to the post with the brown wire attached.
no heat though
any ideas?
Old 22-10-2009, 06:06 PM
kjc300
kjc300's Avatar
bbbbbbump!!
Old 22-10-2009, 06:13 PM
foreigneRS
Testing the future
foreigneRS's Avatar
does the stat switch the neutral?
Old 22-10-2009, 06:17 PM
Cragrat
sit boo boo sit
Cragrat's Avatar
Check tightness of connections to all terminals + check u have 240 @ live + neutral @ element still
Element ccould have gono now. Bud
Old 22-10-2009, 06:19 PM
kjc300
kjc300's Avatar
I dont think so, the neutral is connected directly to the element, the live goes straight to the stat, then from the stat to the other post of the element.
tiny2white
tiny2white's Avatar
disconect the wires to the immersion poles and check if you have Continuity from either live or neutral to earth if so get a new immersion i've seen new ones do this but not blow fuse/rcd
Old 22-10-2009, 06:31 PM
kjc300
kjc300's Avatar
It's the stat, I was measuring wrong there's no voltage from the other side of the stat.
Why would the stat only last 2 weeks??
Old 22-10-2009, 06:35 PM
ryan81
ryan81's Avatar
o the stat is there a small hole in centre where there is a reset switch .. thermo cut out has that popped up
Old 22-10-2009, 06:37 PM
kjc300
kjc300's Avatar
Holy jesus!! There's a bloody trip switch on it!!!
Just took the old stat apart and found it has a trip switch built in
Now, why would it trip? overheating??
Old 22-10-2009, 06:40 PM
kjc300
kjc300's Avatar
Spot on Ryan, had just found the little rascal!!
Old 22-10-2009, 06:44 PM
Cragrat
sit boo boo sit
Cragrat's Avatar
How old cylinder or element
Do you live in a hard water area
element could be 'caled up' causing it to overheat + trip
Old 22-10-2009, 06:45 PM
3drpete
3drpete's Avatar
hey up mate if the actuall body of the immersion has corroded it will keep tripping,
ive had it before a few times, ive changed a few where it has corroded and kept blowing the heater
worth a try bud
pete
Old 22-10-2009, 06:48 PM
kjc300
kjc300's Avatar
Cheers guys,
fitted a new element today, the old one looked old but not too badly scaled.
Hopefully that will be it [touches wood]
Old 22-10-2009, 06:50 PM
ryan81
ryan81's Avatar
if its a new imerssion , i would say a faulty stat they can be quite sensative , i`ve had a few omerssions lately with faulty stats, there very sensative these new stats, is it a grey one with a black arrow for adjusting the temp, if so take stat back to merchants ...
i usually try get the red ring stats usually alot better
tankybaby66
06-02-2016 02:24 PM
Chas
05-10-2015 07:13 PM
Flatlinedan
18-09-2015 12:41 PM
Quick Reply: Plumbers?? Immersion heater stat test !!Where's Tiff?
