any houseold leccys in here?
I have a question for ya
my m8 is doing his bathroom out and wants to put a dimmer in his bathroom, easy peasy so far!
BUT the switch also controls the fan which in an obvious no no, so is there a way using a relay for example that the whole lot can be controlled off one switch ,I'm sure even with it dimmed you could run a feed off the positive output to a relay then run the fan through the other side of the relay
Anyone any Ideas I have tried round the net but it just brings up the same question with lots of arguments about it on diy forums lol
steve
steve
sit boo boo sit
Used to be able to get dimmers that had a normally switched output and a dimmed one in the same module
I have one to remove next week as they are going low energy and its no use,if its still functional he can have it.
it will need an additional conductor/cable run to the fan as a switchwire
sit boo boo sit
right mate i have it in my grubby paw and have checked it will do the task required and its affirmative it will do it
will dimm lights and will supply undimmed switched feed to fan
question is how do i get it to you
are you @ scotch corner this sunday where i can give it to you or post it bud (pm ma your addie or ya mates addie)
let us know bud
let us know bud
LukeT
28-05-2008 07:05 PM
