bypassing toad ai600
Ford for life
my mums boyfriend has lost the keys to his pajero and does not have spare alarm/immobiliser fobs, is there anyway of bypassing it without making the system useless (he has ordered new fobs but wont be there for a few days and needs to use the car.
I dont think it will be easy but any ideas greatfully recieved
tom
tom
there is only 2 cut off points 1 for the starter and 1 for the fuel pump usually so really easy to do just chase the wires from the alarm box to the ignition switch and rejoin them and then see were the other wires go from the alarm and rejoin them were they have been cut.not that hard your just matching the original colours back up job done
There is NOT 2 immobiliser points on the ai600, there are 3, but as said this is what needs to be done, be VERY careful to keep the same black wires together in pairs as they come off, originally they come in a loop that you cut to make two ends from the one wire.
Do you not have the touch key for the ai600, it will be a small shallow socket affair, with three tiny pins in the hollow, as this can then be put in valet mode, and unlike the ai606 will REMAIN in this mode until retouched despite what you do with the keys, if you had a fob it would still operate the CL in this mode too.
You can also enter clock mode by entering the 4 digit code with keys, if the cuts are after the ignition.
