3dr ECU Loom Main Car Connector
Anyone got a picture of a standard 3dr ECU loom connector, its a black 4 pin plug.
i've got one here, but need to know what wire goes where on the plug itself for a retro fit, and cant find the info anywhere.
I know a man who will most likely have this info, as he also does looms, have to phone him over w/e so will pm you if get any joy.
I'd take the pad out and look at me sapphy but don't know if in same position.
Ryan if its the plug I think your on about ?
green = rpm signal
red/black = fuel pump
black = batt positive / ignition live that does not switch to earth when cranking
brown = earth
Regards Doug.
green = rpm signal
brown = earth
Regards Doug.
When the plug is upright as shown on the pic, so that the central slider clip also has a runner either side of it, (where as the bottom one only has the central slider), and so that the 4 spades are parallel to the ground when you look at it, and looking at the plug sothat the wires enter from the rear :-
top left are 2 black wires, top right is black/red
bottom left is green, bottom right is brown/white
doug, cheers for the info, im pretty sure i know the colours by now, its just the conifigation pattern in the plug i was concerned about.
cheers for the info paul much appriciated, will take a picture once installed for furture use. ironically its the only the 2nd or 3rd one ive done with a standard 3dr connector plug out of about 200 looms lol.
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
