Differences Between mk.1 and mk.2 XR2 Suspension
Old Sep 23, 2009 | 10:34 PM
jhot80's Avatar
jhot80
Default Differences Between mk.1 and mk.2 XR2 Suspension
I know that they have different anti roll bars and same differences in the shocks and stuff but there are there any major changes that were made to the geometry or chassis?
James
Old Sep 24, 2009 | 07:33 AM
andrewg's Avatar
andrewg
i'm sure years ago i sawped struts and the tracking was a mile out but after that was corrected it was mint,, maybe the bolt holes slightly different for camber
Old Sep 24, 2009 | 07:50 AM
Bomber's Avatar
Bomber
Rears should be the same (both had an antiroll bar), Mk1 fronts are longer than Mk2 items so if you fit Mk2 front's you'll get an extra 20mm or so drop.
Both can be interchanged though, but be prepared to hunt about for the right springs for the front if you want an even drop all round if your mixing and matching mk1/2.
Rally design will do you any poundage and length springs though.
Old Sep 24, 2009 | 08:00 AM
Graham S1's Avatar
Graham S1
Tonnes of info here....
http://www.fiesta-mk1.co.uk/forum/vi...ighlight=guide
Old Sep 24, 2009 | 05:39 PM
James's Avatar
James
also the mk2 had a slightly wider track, so i think the bottom ball joints are different and the positioning of the holes in the shock where it bolts to the hub are different between mk1 and mk2 front shocks.
Old Sep 27, 2009 | 03:27 PM
jhot80's Avatar
jhot80
well i was only asking because there is suspension kit avaliable for a mk1 from america. But by the sounds of it i should fit a mk2.
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
