2litre focus N/A plus turbo
With decent management and cooling etc how much psi could you run through a stock 2litre blacktop in a focus?
just wondering if you could run say 3/4psi using a focus RS manifold and turbo just to give a n/a blacktop a bit more go?
Or is any positive pressure on a standard compression blacktop not a good idea?
the pistons wont like boost and high comp.
p-s i ran 10.3.1cr and 20psi boost on my st170 turbo there was no margin for error tho and i would never run that sort of cr again
ZETEC TURBO
my mate use to run 7psi on a completly standard focus black top, it had a focus rs turbo and manifold and charge cooler system, on standard managment, went well but ended up melting a pistion and blowin it,he run it for about 3k miles ok untill a long 120mph + run down the motor way and it blew up
There was a zetec na/turbo build done in turbo magazine ages ago, they managed to get just under 1 bar(cant remember which turbo) which knocked it upto 270hp. They only mod(bar the obvious) i can remember needed doing was the inlet was retarded 5,6, maybe 7 degrees.
If the afr's and egt's are in check i dont think that is pushing it to much. The mapper will know best though as he will be able to find where det is and dial in a certain amount of safety margin. The bigger the margin the less power your gonna make.....but then to little ignition is going to put too much heta into it, double edge sword,lol.
sounds like it maybe ok running no more than half a bar or something- would see a solid 200bhp from that anyway i reckon.
mapping would be the big point I spose- nice and rich lol
It would be mapped and setup properly not on standard management just wondering how the blaxktop would hold up or whether it would be very short lived at standard compression?!
that was my thinking- could run 200bhp or so before doing a proper build to run more power etc
EDIT: Or get a decompplate so you can run more boost.
don't wanna be messing about with decomp plates hence the question.
simply thinking about a future project mate and a way i could do it in stages- proper build etc would come later along with other things but i'm not in a position to just chuck money at fresh builds with a great spec outta the box etc.
i'm running a tad over 200bhp at 7-8 psi on my sc'd 2 ltr blacktop mk2 mondy (zetec) with stock internals and a unichip. had no issues and done around 17k miles.
i just upped the boost yesterday have run it up to 9 psi at around 5k rpm so should see 10-11psi at redline but havent taken it there as the aux belt needs replacement.
money would be spent it would just be on other things and in stages just wondering how well the standard engine will cope with some turbo pressure.
So spending X amount on a simple well setup turbo at low pressure with a view to using that setup for a better engine later rather than spunking loads on a N/a engine without any other route to go afterwards is stupid?
sounds so easy to do
cant wait to here about the results.
no trying to hijack but do ya think i cud do the same thing on a 1.8 black top focus?
got me thinking lol
got me thinking lol
PassionFORD Member
1.8 blacktop is at a major disadvantage in comparison to the 2.0 mate. Reasons being:
1) Internals aren't forged and will not take as much power as a 2.0. Safely might be around 180bhp.
2) No under piston oil cooling jets.
3) IB5 gearbox is considerably weaker than the MTX unit. Won't like anything more than around 180ft.lbs.
Matt Baxter
16-09-2015 08:30 PM
