problem found.can delete.thanks.
Old Sep 18, 2009 | 04:40 PM
stevenebm's Avatar
stevenebm
post whore
Default problem found.can delete.thanks.
i know its not the tech section but im at my wits end.my s1 has cossie brakes all round.got an easybleed kit and have bled them up no problem.thing is when the car is running there is no pedal atall and when you press the brake pedal in the revs climb a bit??am i drawing air from somewhere or is servo knackered??any you rst guys had this before?
Old Sep 18, 2009 | 04:44 PM
Dlatch!'s Avatar
Dlatch!
classic knackered servo symptoms
Old Sep 18, 2009 | 04:46 PM
stevenebm's Avatar
stevenebm
post whore
if it is mate i have no problem gettin another.its just weird it was fine when i took it off before resto,anybody explain how the servo works so i can get my head round it.i took master cylinder off and the seals in servo there look ok.where else is there seals.at the rear?
Old Sep 18, 2009 | 06:19 PM
Rick's Avatar
Rick
when bleeding the rear brakes, you need to undo one of the caliper mounting bolts ad swivel the caliper so the bleed screw is the highest point, otherwise air will stay trapped around here giving you a soft pedal.
Rick
Old Sep 18, 2009 | 06:22 PM
stevenebm's Avatar
stevenebm
post whore
found the problem mate.the servo is goosed.took it off and blew in to it.no leaks atall.soon as i pressed the bar at the back it all escaped.it will be doing the opposite on vacumm and drawing air in.got one on its way to me
Old Sep 18, 2009 | 06:44 PM
BM08's Avatar
BM08
Can i just say if every post that was sorted/answered/fixed got deleted then there would be no forum
Sorry, pisses me off when peope say " problem sorted, mods delete"
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
