Can any1 on here do gear cutting? Or know anywhere?
Old 18-09-2009 | 12:51 PM
stu21t's Avatar
stu21t
Default Can any1 on here do gear cutting? Or know anywhere?
I wanna get a shaft made and need some gears cut into it,
it needs 2 splines, 2 straight cut gears and 1 helical gear.
I can supply the material.
I have a STD shaft to copy and a pic of new and old next to each other, basically the STD 1 is in 2 parts and I want it made out of 1 piece.
Can any1 on here do it? Or have you used a company before and recomend them?
If they are in/around London I can bring the parts down and discuss it.
Old 18-09-2009 | 03:54 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
There's a place called Bronte Engineering in Bradford, ask for a chap called Steve Leach - i know they can do gear cutting as well as most precision engineering.
I appreciate it's not London, but might be able to help.
Tell him Will Pedley sent you
Old 18-09-2009 | 04:07 PM
stu21t's Avatar
stu21t
Thanks for that m8, will give em a try.
I have found somewhere semi local and am waiting for them to get back to me.
timsrs
13-11-2018 12:48 PM
Mark RS
12-10-2015 07:01 AM
07-10-2015 01:56 PM
The Youth.
30-09-2015 10:59 PM
Fudgey
21
30-09-2015 07:19 PM
