throttle bodies on an st170
Ford for life
thinking of doing this but not got much idea what bodies i need etc, will standard injectore work and stuff, any infro greatfully recieved
There's loads of choices of tb, that will fit with appropriate inlet manifold.
The ecu will need remapping, don't know whether your std injectors will fit, but tb suppliers will.
JENVEY do some ace ones, but expensive.
Ford for life
im talking bike throttle bodies, that fit to the existing rubber bits on the st170 inlet manifold
Ford for life
I want to do all the work except mapping myself. I know I can use bike throttle bodies with my existing manifold mountng plate (incase your not aware the st170 inlet is attached via rubber hose to the a mounting late attached to the head meaning the trottle bodies will fit against the existing plate and hose bit thingys) but its like which bodies i need, how do i go about the throttle cable linkage etc, what else is required, is standard fuel pump up to job etc
thanks
tonm
thanks
tonm
you will have to just make a cable up, think the gsxr 1000 will be ok for the job and as for the injectors you will have to see what sort they will take.
have done a few st170 on TB and they all run so much better
I imagine it will need a new ecu rather than remapping the standard.
This is the site with the how to artical
http://www.mez.co.uk/ms10.html
Mark
Edit to add that there does not seem to be a mention of how the ali tubes were fitted to the bodies ?
Also get the earliest GSXR bodies you can, the first ones only had one butterfly and newer ones had a second that will need removing.
Mark
Hi mozzy, i'm running a black top zetec with Gsxr 1000 tb's, as gordon1 say's they run a hell of alot better and smoother, the thing about the Gsxr tb's is that you can separate them into individual's so there straight on to the port of the head, plus there tapered 42mm at the head and 54mm at the trumpet end which is great for forcing air in, a universal throttle cable should see you right, also i'm usine the Gsxr injectors which have a flow rate of 220cc which is plenty for me running at 200bhp you may have to go bigger but depends on what your plans are..
I found this one also
http://www.linktobusiness.co.uk/foru...hp?f=16&t=1960
The main problem is space, there is not much room between the inlet and bulk head, most inlets foul the alternator, you will need a complete new ecu unless you fit an air box to thew bodies with a single inlet to run the standard sensors
Ford for life
excellent link, looks a lot easier than i thought but still quite daunting, i might buy a spare manifold etc and make that up as in the diagrams first
does anyone have another link to a how to?
The one Sp3no put up is fantastic but the pics aint working? im stuck with the throttle cable/bracket modification? as soon as im sussed there then its another ITB'd zetec on the road
mk3ste
17-10-2021 10:09 AM
