ST170 Turbo - keeping VVT?
Is it worth keeping on a turbo application?
I understand it allows it to be more drivable, but its going in a car that will be taken to Ford shows and Pod only.
Chip suggested the other night for this reason leaving it off, as it complicates the mapping side of things too..
Anyone got any knowledge/expereience VVT & turbo drivibility and mapping?
Si what management are you using?
I know on zsoc there is a person with omex 600 who can't seem to get the vct working on there throttle bodied puma engine. Im not sure if it was todo with omex or instalation or whatever but Track and Road aint been able to get it working.
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
the problem is that the vvt changes the ve of the engine and has an effect on turbo spooling, so you can find yourself going round in circles come mapping. yes it can make a big difference e.g. spooling a big turbo quicker. is it absolutely necessary in a highish compression engine with modern turbo and proper management and boost control, i wouldnt necessarily say so. personally, as its there, id keep it functional and maybe map it flat for now to save time and money, then consider having it fully mapped when funds allow and more power is desired!!!
Good point on that theres no point in loosing it, just didnt want to over complicate things if need to by creating problems...which apparentely there are using my ECU (Omex 600 would you believe )
I read Omex 600 could run cam control but thats for electronic based only I am guessing?
Looks like Ill have to leave it out then!
Will - Is mapping it a lot more trouble (than its worth essentially?)
if you only want that power then a standard black top head will it no probs and be much easier to map, just my opinion tho and yes i have been down the vvt road .
No point in using a blacktop head over a ST170 head without the VVT though? They have solid lifters and bigger ports and valves?
I remember reading you had mate, and I remember you saying how good it was and how is worth the extra mapping/complications at the time, but then you changed your mind?
i did change my opinion on it mate .but a blacktop head has solid lifters aswell and only the inlet ports are bigger and the inlet valves are only 0.5mm bigger,all you get is a head that can get more air in at a slower speed but cant get it out fast enough and the cams are a bit on the aggressive side for turbo but again just my opinion on it.
If you find the cams are strangled for power you could get them re-profiled for more lift
VVT and turbo can, and has been mapped 100% perfectly, with outstanding results.
The VVT massively helps economy on lighter throttle openings, not that your concerned with that.
I knew the blacktop head had solid lifters too, and I know only the inlet ports are bigger. Why do you say the cams are aggressive? Ive read they react to turboing well?
And what made you change your mind about the ST170 heads anyway?
but when i compare this engine to my st170 this one would piss all over it mate ,when i was comparing the vvt spool up i was unplugging it so it made a massive difference !!! or so i thought lol my blacktop is more responsive and more powerful far more simple easier to map cheaper to build and does what it says on the tin.
but dont let me put you off mate if want to use it go for it and let me know how you get on with it.
rick off here is also going down the st170 /vvt road at the moment.
The issue is that VVT is very difficult to control. Most ECU's cannot even read the 5 tooth cam wheel! It needs a very clever closed loop algorithm in order to keep the cam position constant for any given load site. A couple of very expensive ECU's advertise they can do this, but i haven't seen it implemented yet. Megasquirt 3 will be able to do it once they have rewritten the code to work with angle clock, which is how the OEM's do it.
The other option is the on/off method. With power off, the cam is very retarded at 145 degrees. With power on, it's at 85 degrees. These are huge extremes, and i doubt the OEM setup ever gets to these extremes except in limp home mode. I haven't tested yet, but i don't think that these extremes will be anywhere near optimum for power.
On my car at the moment, i have retimed the inlet cam with a dti/degree wheel so that in the most retarded position, the inlet is at 110 degrees - around what the timing would be setup if it was fixed. I never power the solenoid, so the timing stays here all the time. Simple way of removing VVT, until I sort some proper closed loop control.
Rick.
Rick.
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
