Escort Cosworth front bumper adjustment and removal UPDATE PLEASE READ NEED ADVICE
After several hours of trying to remove the front bumper i finally got it off, i originally thought screw had been threaded as all it did was keep turning, jacked it up today and looked at bolt and found the problem the square screw/oblong threaded thing that sits in the front support had come away and was just turning on the screw,
So how do i re-put it in and make sure it stays there????
Help
Help
Monte 087
Was it a star drive ot 17 mm bolt you took out the star drives are only supposed to be the height adjusters i made this mistake the first time i took my bumper off?
It was the star drive as bumper had well dropped and found the problem to be threaded nut/insert hence why it just kept turning.
Do you think Chemical metal would work???????
Tried to tap it back in and when put bumper back on it did the same
probably best to remove the whole bumper, remove the plastic twists, 1 each side of the bumper below the sidelight & back a bit,,,,, then theres 4 17mm bolts underneath the chassis legs at the front, remove the back 2 & losen the front 2, the bumber should then come off & you can sort out the adjusters.
JoeyBoyden
04-01-2024 02:36 PM
Escortdriver1
31-07-2015 02:36 PM
