One for Chip 3door
#41
the e16se doesn't require massive amount of setting up
the airflow meters are what go wrong on them they don't take kindly to air filter your better off with the standard air box and a good panel filter
just make sure the timming belt has been changed have the timming setup and the CO level checked it will only require four wires to be run correctly.
Hi chip i'm finally back at work now HA
converting 1 to run twin 40's is quite simple use a 1.4sr distributor and coil inlet manifold and lowering alternator bracket just make sure the 40's are jetted correctly for the 1.6
#42
Almost there!
Another possible route would be to get hold of a set of 2L 16v injectors which directly fit, change the fuel pressure regulator to compensate and then get it mapped to suit as the injectors have a wildly different spray pattern.
this doesnt always add greatly to the power but driveability wont be sacrificed and the torque figures do go up!
#43
Hello matt mate, good to see you on here again
When you coming down next to f*ck that blonde bird with huge tits who lives near me, im sure she is missing you again by now, just please dont do it anywhere that belongs to me next time, im fed up cleaning your muck up off my car seats and beds and sofa!
#44
HOW?
They dont come with autronic as standard you know mate!
#45
Ha cheers for that lad must admit u could do with cleaning the volvo out.
will try take some time off and take the S1 for a run down south
#46
Good lad
Might be best to wait till after the new year though, as my cossie looks like being about february till its on the road (which is cool as my 30th birthday is 5th of feb)
Either that or i'll drag her along in a couple of months when i come up there in the cossie?
#48
Almost there!
HOW?
#49
i might even have to come down and help ya sort that cossie out all being well i hope to have another cossie myself by then
