Escort Cossie front bumper removal(HELP)
![Angry](https://passionford.com/forum/images/icons/icon8.gif)
I cant seem to remove one of the star keys from the bumper all it is doing is turning in both directions
The bumper has dropped so does any 1 have any suggestions of how to remove it so i can get a replacement and re-align my bumper
there are 2 bolts you have to undo, there in the square box part of the chassis and there are 2 you loosen off, you don't have to take then out,in the same place.
you have the parts thats connected to the wings then,iirc, 13mm bolts to come off then it should be off.
Was just about to post the same thing
Easy enough job to do
The 2 torx bolts are just for adjusting the height of the bumper.
The way I do it:-
Remove the two plastic 1/4 turn retainers from both sides.
Behind the bumper in line with the torx bolts are 4 x 17mm headed bolts, you need to loosen the front two and remove the two nearest the engine.
you can then pull the bumper slightly forwards and disconnect the indicators and fogs.
Then the headlamp washer pipe - but it's quite long so you can get away with that, depends what you are doing.
The way I do it:-
Lol thats what im having trouble doing removing the bumper have a tap and die set to re-thread but need to remove it first any suggestions
