L8 Board???
Passion for Fords!
yes they have a std ford board.
and some are chaged to pectel boards, so you need to know what you have and what method of encryption your chip is written for
ie, if you put s a std ford encrypted chip into a pectel board it wont work, and vice versa
Testing the future
all l8s need a board. there are basically 2 types of board though, std and encrypted (most commonly using the pectel protocol). the chip needs to match the board.
yes they have a std ford board. Pal
and some are chaged to pectel boards, so you need to know what you have and what method of encryption your chip is written for Pal
ie, if you put s a std ford encrypted chip into a pectel board it wont work, and vice versa Pal
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
If you can get another connector, very easy, it just pushes on over the ribbon cable, no tools required.
I've kept meaning to get a run to somewhere like maplins to see if they've got them in stock, keep forgetting though!
DixieTheKid
11
06-06-2020 11:20 AM
