rad stop leak does it work>
Old Dec 20, 2004 | 08:45 PM
tonypastie's Avatar
tonypastie
Default rad stop leak does it work>
as above really spent to much money on my frontera already every now and again steam comes from the top edge of the rad would some stop leak really work >? and what would you use ?
cheeRS
tony.
Old Dec 20, 2004 | 08:51 PM
Alvyn's Avatar
Alvyn
crack 2 fresh eggs into the header tank works wonders.
Old Dec 20, 2004 | 08:53 PM
TrickyDicky's Avatar
TrickyDicky
Tony
try holts "radweld".
works wonders.
Tricky
tonypastie's Avatar
tonypastie
"two eggs "
fook that but thanks !
Old Dec 20, 2004 | 09:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i've used radweld as above and worked perfectly on my old s2, well not as perfectly as shelling out for a new rad but you get me
Old Dec 20, 2004 | 09:02 PM
NUTS RuS's Avatar
NUTS RuS
If the rad is metal use Kalimex K Seal
I never go anywhere without it
Old Dec 20, 2004 | 09:04 PM
tonypastie's Avatar
tonypastie
no its a modern plastic top thing
Old Dec 20, 2004 | 09:09 PM
NUTS RuS's Avatar
NUTS RuS
Kalimex Seal-Up then
Try Ebay or http://www.kalimex.co.uk/section.htm...=01.03.&pgid=2
Old Dec 20, 2004 | 09:12 PM
tonypastie's Avatar
tonypastie
how much does that stuff cost ?
Phil's Avatar
Phil
Jeebus
What about turbocharged engines? Will it mess up the water cooling?
Old Dec 20, 2004 | 09:21 PM
NUTS RuS's Avatar
NUTS RuS
Online Ł8.95 I think.... or about Ł7.95 on Ebay Tony
Old Dec 20, 2004 | 09:28 PM
tonypastie's Avatar
tonypastie
cheeRS will look in to that you reckon it will work new rads about Ł80 just spen Ł321 today on it having lpg system sorted out
Old Dec 20, 2004 | 09:37 PM
NUTS RuS's Avatar
NUTS RuS
ALWAYS worked for me Tony I always carry K Seal in my kit as it has been known to fix cracked blocks, headgasket leaks etc etc. Only does its stuff when forced under pressure and in contact with air so should cause no problems Phil.
Worth a try i'd say
Old Dec 20, 2004 | 09:42 PM
tonypastie's Avatar
tonypastie
Old Dec 20, 2004 | 09:45 PM
jaimesdna's Avatar
jaimesdna
dont b cheap mate. i used radweld & my cossys now been off the road 4 3 years . it tends 2 block the rad so not much water can get through. my mate had the same problem with a car of his. in the long run its much cheaper 4 a recon/new rad. if u do use anything like radweld keep an eye on the temp gauge at ALL times.
Old Dec 20, 2004 | 09:48 PM
Alvyn's Avatar
Alvyn
Originally Posted by tonypastie
"two eggs "
DONT knock it till you've tried it m8. worked fine when I was stuck with a small hole in the rad
Old Dec 20, 2004 | 10:31 PM
escort1989uk's Avatar
escort1989uk
mate had a leek use two eggs and now the engine is noisey good cheap fix but get it sorted, buy a used rad from a xr3 from the breakers yard and back flush it will only cost you a score as i think the turbo on the s1 ain't water cooled but don't ask me. ain't a wizz kid on this stuff
Old Dec 20, 2004 | 10:44 PM
NUTS RuS's Avatar
NUTS RuS
But its a Vauxhall Frontera Wizz Kid
Old Dec 21, 2004 | 06:51 PM
tonypastie's Avatar
tonypastie
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
