help with 3 door
How do you slacken off a 3 door cossie handbrake cable, im fitting new rear calipers and cant get the cable off the old ones
Slackening off the handbrake cable isn't the correct way of doing it, the only thing you'll end up doing by trying to squeeze the hook off the end of the caliper is stretching the secondary cable.
The correct way to do it is to disconnect the secondary cable from the primary. There is an equaliser on the end of the secondary cable (hidden up behind the prop) which is connected to the primary with a pin and clip, remove the clip and push out the pin (g-clamp and socket work well for this) . Its more aggro to disconnect it all but its quicker in the long run.
Resident Wrestling Legend
then use a screwdriver to simply prise the hook end over the top
the other side willnow have enough slack in the cable to get sorted
it's a right pain in the arse to do first time aruond, but once you know how it's a 2 minutes job
easier with the wheels off though, just in case you were trying to do it through the spokes
got the new ones fitted now so the car moves again, now i can get it out the garage and get the handbrake adjusted etc
Thanks for all your help
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
Vacuman
22-09-2015 12:09 PM
