Cooling system
Old Sep 3, 2009 | 04:02 PM
vinnya77's Avatar
vinnya77
Default Cooling system
Has anyone upgraded the cooling on their cossie's? Mine is running alot hotter than it used to now I'm using a GT30. If so what can I do? Oh yes it's a 93 escort.
Thanks
Old Sep 3, 2009 | 04:32 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
A decent big radiator would be the starting point. Then a turbo cooler rad that takes the hot water exiting the turbo into the cooler and then back into the header tank. Sits on top of the normal rad. Pro-Alloy do the whole kit.
Old Sep 3, 2009 | 04:39 PM
andy escos's Avatar
andy escos
air tec is a hell of a lot cheaper though & they work brilliantly
Old Sep 3, 2009 | 04:48 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Airtec are also bloody heavy stuff - it's like having an industrial grade radiator strapped to your car
Old Sep 3, 2009 | 04:52 PM
CossieRich's Avatar
CossieRich
I only said pro-alloy as thats what i use. Im sure its all like for like with big rads and turbo coolers
Old Sep 3, 2009 | 04:56 PM
andy escos's Avatar
andy escos
true they are heavy but they do a very good job for very little money
Old Sep 3, 2009 | 05:25 PM
vinnya77's Avatar
vinnya77
Is there enough airflow above the my rad to have much effect on the cooler? Not too bothered about the weight difference between the 2 mentioned, more about the job they do.
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
coscor86
Sep 20, 2015 01:21 PM
