fook me it rough tonite
we are towing the rig in the indian ocean, 12 -15 metre swells tonite, tug boat cant pull us so we are going backwards at 2 knots.
20-25 degree roles, i want calm weather
Never gonna give you up!
Yeh, well it's raining that much our water butt is full and I'm having to go out in the rain and empty it into buckets and throw it down the drain.
You thought you had it hard!!
burnzy
just spent 2 weeks in mallia and now back to this rainning dump Whoo!hoo! ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
but as said pics of big waves would be good i'm fasinated by the sea, and how powerful it can be
Patronus
heating on ??? behave people !! it's pretty warm here still, garden thermometre says 20 degree's even though it's pissing down !!
i'd love to see pics too !!! ( not of the heating before you funny fuckers start !! )
Blackford Dolphin
GENERAL
Flag: Singapore
Manager: Dolphin Drilling Ltd.
Year Built: 1974. Major Deepwater Upgrade 2006/2007
Builder: Aker Nylands Verksted AS, Oslo, Norway (1974), Keppel Verolme (2006/2007)
Design: Aker H3
Classification: DNV + 1A1, R, Column Stabilised Drilling Unit, HELDK-SH, CRANE and Drill
MAIN DIMENSIONS
Length: 108,3 m (355,3 ft)
Breadth: 84.1 m (276 ft)
Height: 36,57 m (120 ft), Main Deck elevation above baseline
OPERATING PARAMETERS
Water Depth: 7000 ft Maximum (Outfitted for 6000 ft)
Maximum Drilling Depth: 30000 ft (9144 m)
Transit Speed: 4,5 knots (towed)
Survival Conditions: Hs 16,8 m (Hmax 32 m), Max wind 100 knots, Current velocity 2,0 knots
Drilling Conditions: Hs 8,4 m, Max wind 100 knots
CAPACITIES
Variable Deck Load: 4500 mt (9,920,802 lbs)
Liquid Mud: 5000 bbls (596 m3)
Bulk Mud/Cement: 8 x 2170 ft3
DRILLING EQUIPMENT
Derrick: 1500 kips (750 st) Static Hookload Capacity, 40 ft x 35 ft x 160 ft
Drawworks: NOV SSGD – 4600 with 4 AC Motors
Rotary: NOV D-605, 60 ˝” opening
Topdrive: NOV (Hydralift) HPS 750-E-AC-KT with 750 st Load Capacity
Riser Tensioners: 6 x NOV DWRT-200-50 Dual Wireline Tensioners, Max capacity 2,400,000 lbs
Motion Compensators: Crown Mounted Compensator, 1500 kips static / 800 kips (363 mt) compensating load
Mud Pumps: 3 x NOV 14-P220 with 2200 hp each
MACHINERY
Main Power: 4 x Catepillar Model 3612, 3800 KW, 5096 Hp Max continuous power
Emergency Power: 1 x Caterpillar 1800 KW
Propulsion: In-line propulsion system (Propulsion assist mode only)
SUBSEA SYSTEMS
BOP: 18 ž” Hydril 15k (2 + 3 Cavity)
Control System: ABB / Vetco Multiplex system
Diverter: Hydril FS 1500 psi
Choke and Kill: 3 1/16” RB Pipetech 15k H2S (including Mud Gas Seperator)
MOORING
Winches: 8 x NOV BLM W325 AC Single Wildcat, Electric, 293 mt rated pull
Wire/Chain: Wire / Chain combination
Anchors: 8 off
CRANAGE
2 x 85 mt @ 16,7 m Knuckle Boom Cranes
ACCOMMODATION
130 (120 in 2-man cabins)
This gives you some idea how big it is, and the sea is chucking us about like a cork just now.
GENERAL
Flag: Singapore
Design: Aker H3
MAIN DIMENSIONS
CAPACITIES
DRILLING EQUIPMENT
MACHINERY
SUBSEA SYSTEMS
MOORING
Anchors: 8 off
CRANAGE
ACCOMMODATION
burnzy
Maximum drilling depth 30,000ft ![](https://passionford.com/forum/images/smilies/shocked.gif)
can i ask what happens if you was in the middle of drilling and you got hit by rough sea's, i'm guessing cos it floats they'd be movement wouldn't it bend or break drills.
i obviously have no idea of rigs so be gentle with me
Patronus
just looked at some piccies of it on google..
http://images.google.co.uk/images?hl...-8&sa=N&tab=wi
it's fuckin huuuuuuuuuge
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
we can drill in up to 8m of swell as we have a heave compensator at the top of the derrick, this will keep a constant weight on the driling bit. think of it as fucking huge shock absorber
rich_bloor@hotmail.com
they're sucked into the ocean bed with a vacume so they dont move when drilling, i think...
burnzy
guess if it's any more than 8m swell then you have to stop in fear of breaking tools.
just one more question and i'm finnished
when you have drilled into something i.e oil or gas and say the sea got ruff and you did have to pull the drill out what do you do to stop the oil or gas escaping from the hole made.
Series 1 4x4 cossie
Mines on tow down to cape town just now, bet you wish you were on that, nice calm waters!!!
http://www.prideinternational.com/fw...fic-18C65.html
Series 1 4x4 cossie
theres always something good about being around big machinery
, i wouldn't be able to keep my hands to myself if i was there ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
honestly
we use drilling mud, usually when you drill into a formation you take a leak off test, this will tell you how much pressure it takes to push into the formation ie weight of the fluid you are using to drill with. when you pull the drill bit and jewellery out the mud obviously stays there, and keeps a constant weight against the oil and gas trying to scape into the hole, which only has one way to go when it gets in there.....
for those that are interested.
hydrastatic pressure = mud weight(ppg)x.052x tvd (true vertical depth )
this will give you psi at the bottom of the well.
Chief Iron Oxide Farmer.
Crazy. I wouldnt want to be on a rig in this weather!
I thought I had it bad, I couldnt hold the bicycle straight across the beach road this morning. Wind howling across the sea nearly blew me clean off a few times.
PF Idiot Sniper
i hate being on a semi
the drill bit is only the part on the very bottom and maybe 1-2ft max height. Rest is tools etc(jewelery as Bob called it) and run on drill pipe. If there is bad weather you can suspend the drill pipe at the sea bed down wards. You have a riser betwen the rig and seabed which is effectively the start of the hole which is then unlatched and pulled to stop the heave pulling it to bits. The drill pipe, bit, tools etc run inside this riser with drilling fluid and it's not seawater.
Any more questions just ask. It's a fascinating business
As said above its not the bit size thats the problem its the amounbt of drill pipe to run it on, oh and the earths core
burnzy
Oooooo! yea it is fascinating
will have more questions later just having a bit of a chill out and some ouzo so my head is on tickover atm
, but thank for the replys and also the lamens terms from lamchop ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
i'v worked in big factories whilst sparking and i can't help but get drawn by all the big machinery i always have to have a nose about
i find it hard to work sometimes, like the big foundry i worked i n a few times with the biggest lathes in europe for making battle ship propshafts and stuff like that i'd be amaized for hours
You might be thinking of a jackup which has large legs that sit on the seabed and you can jack the rig height to suit seabed level. Canonly be used in certain shallower depths though.
Might be, Richard Hammond told me all about it on one of his engineering programs. It might have been on Discovery... Mabey.
