Wall mounted plasma people.
Hello,
I mounted my Plasma on the wall the other day.
I made the brackets myself because the 1s in the shop didn't fit close enough to the wall, it's now mounted about 10mm off the wall, now the problem is I only have 1 HDMI slot on the side, the other 3 are on the back, are there any 90 degree angled HDMI leads, I suppose the other way is to chisel the wall out to clear. I managed to strip the power lead down and make it a lot more slimline, the HDMI cables won't be as easy though.
Thats what i've used, then just trimmed an extra 5mm off the plastic casing and it fits perfect.
i fitted a new lcd tv to a customers house that we reccessed into the wall by about 50mm
that doesnt overheat, we left a 50mm gap around the tv and thats fine.
ive not seen any cables at a 90degree angle tho.
sit boo boo sit
Lcds don't gat any where nearas hot as a plasma that is tha beaty of installing them over plasmas
I had to do a lot of research to find out how much space I neededand what temp stat had to dwitch on at,think I got it right as its been there for s.d yrs now with no problems
sit boo boo sit
Lcds don't gat any where nearas hot as a plasma that is tha beauty of installing them over plasmas
I had to do a lot of research to find out how much space I needed and what temp stat had to switch on at,think I got it right as its been there for 4.5 yrs now with no problems
All sorted now, cheers Danneth
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
