who's got sky HD.....old box IS better...why
Old 31-08-2009, 09:10 AM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
Default who's got sky HD.....old box IS better...why
had HD fitted and the picture is mint, but my normal sky picture seems/has gone crap.......when the bloke fitted the HD he said what a good picture i had on "normal" sky.........anyway now with a new dish n HD box my normal channels really have lost quality......help.....i've still got my sky+ box so i'm thinking of setting that back up to check the picture....
Old 31-08-2009, 09:14 AM
Ebonycossie4x4
Ebonycossie4x4's Avatar
maybe youre just used to the HD
i have HD and standard pictures have not changed really.
Old 31-08-2009, 09:30 AM
Rhys
Rhys's Avatar
as said above lol. But other than that its fine here.
Old 31-08-2009, 09:37 AM
pete mcrash
fook knows......i'm still going to plug my old box in and see........probs just me....lol
Old 31-08-2009, 01:56 PM
Porkie
Porkie's Avatar
check the settings. Like make sure new box is set to RGB and not Pal etc etc
ALL the channels should be slightly better on a HD box... as you are now using a HDMI cable instead of a scart I take it?
Old 31-08-2009, 02:28 PM
dojj
Resident Wrestling Legend
dojj's Avatar
it's your eyes telling you that the hd pic is so good that the normal pic is now crap
look at the pics in the program menu, they should all be in hd
or check out the indian channels, 784 seems to have the best cheap quality version of film on it to make a good comparison
Old 31-08-2009, 03:00 PM
pete mcrash
....yeh using the hdmi that came with it.........but deffo a worse picture on "normal" sky....even ch 1,2,3,4,5 arn't as good......when i had the 2nd box fitted (1st had a fault) the bloke did a signal test and said it was good........i've fuckd on with a few different settings on the HDbox and t.v and it's no better......
Old 31-08-2009, 03:02 PM
pete mcrash
....Dojj i know what ur saying but i still think the quality is down......and NO i'm not putting any Indian channels on............
Old 02-09-2009, 02:55 PM
pete mcrash
well just plugged my sky+ box and back in and the picture is deffo better on it......why am i getting a better "normal sky" picture on an old box and scart lead.....wtf
Old 02-09-2009, 04:11 PM
cozmeister
More boost Igor!
cozmeister's Avatar
Because the analogue SCART input helps mute some of the nasty compressed video artefacts, like the blockiness. Watch SD channels through the SCART input, and use the HDMI purely for HD channels. For as long as digital TV uses highly compressed video, it will always look poo. It doesn't help that they're trying to squeeze more channels in, and more HD channels into the same bandwidth - the only way is to reduce the bit rate of the rest of the channels, which gives the picture even more compression artefacts.
I don't agree - even on my 5 year old FD Trinitron (don't dis a quality CRT), Sky Digital's picture quality has been going slowly downhill over the last 10 years as they've been squeezing more channels in, reducing the bandwidth for the rest. The nasty compression artefacts are more obvious now than ever before.
Old 02-09-2009, 04:18 PM
pete mcrash
just got off the phone to sky......and apparently it my T.V.........when i told them i had a Viera he said it was a fault with them.....my HDCP is interfering with my HDMI board........i can see lots of phone calls tomorrow........
Old 02-09-2009, 06:25 PM
Rhys
Rhys's Avatar
On a side not anyone got the new Sky Software yet with operating system? My bro has it but i dont
Old 02-09-2009, 06:36 PM
Stu.H
Stu.H's Avatar
It is probably you getting used to HD.
I know when I watch a HD film off my PS3, I cant even watch normal terrestrial.
Shocking!
Old 02-09-2009, 06:38 PM
pete mcrash
Shocking!
.....have u read the above.....
Old 02-09-2009, 06:39 PM
Stu.H
Stu.H's Avatar
Just a contributing factor
Old 02-09-2009, 06:40 PM
pete mcrash
......dont know..........when they put the box in they downloaded new software.....
Old 02-09-2009, 07:04 PM
Rhys
Rhys's Avatar
it looks 100% different to old sky format. I'm new customer with new HD box and still on old format even though they updated it etc.
Old 02-09-2009, 07:12 PM
pete mcrash
.....no then, it's the same as it was......
Old 02-09-2009, 08:05 PM
dojj
dojj's Avatar
it's the over air software update they do to make sure the stuff is up to date as possible
it might be that the hdmi cable is the problem, have you tried to connect the hd box via the scart lead to see what the difference is yet?
Old 03-09-2009, 03:58 PM
Jim Galbally
Jim Galbally's Avatar
rhys the boxes only heck for updates periodically, theres a way of manually forcing it to do it tho, just google and you should find it, you press some buttons on the front when switching it on..
Old 03-09-2009, 04:04 PM
pete mcrash
[quote=dojj;4372372]it's the over air software update they do to make sure the stuff is up to date as possible
it might be that the hdmi cable is the problem, have you tried to connect the hd box via the scart lead to see what the difference is yet?[/quote]......on "normal" sky it's a better picture...but a scart lead cant produce a HD picture....so it kind of defeats the object....the t.v's going back on satdy and an engineer is fixing it on mon/tuesday....i'm getting a load t.v.........
Old 03-09-2009, 04:29 PM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
To update the software you pull the power lead out the back of the box, hold down the backup button and plug the power lead back in. Keep holding the backup button down until you get a screen on your tv saying updating system software.
this was on my sky+ box. I cant see any other box being any different. Hope that helps.
Old 03-09-2009, 04:33 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Same procedure on the HD box to upgrade the software as a Sky+ box
Old 03-09-2009, 04:34 PM
CossieRich
CossieRich's Avatar
there we go then. All rush off to your sky boxes to update lol
Old 03-09-2009, 04:35 PM
RS SHAUN
RS SHAUN's Avatar
anybody getting itvhd through sky?
Old 03-09-2009, 04:36 PM
cossiestu
cossiestu's Avatar
Yeh, its the same for all sky boxes Rich...
Old 03-09-2009, 04:39 PM
Graceland
Team HOTHOT!
Graceland's Avatar
No
Aparantly, ITV haven't signed a rights deal with BskyB so they won't transmit ITV-HD over Sky - it is available on Freesat and Virgin though....
Old 03-09-2009, 04:41 PM
Porkie
Porkie's Avatar
Yes, very easy to do... but its a pain to watch as you cant flick around channels.
Still pretty cool for films or football though
CossieRich
CossieRich's Avatar
so what is the difference after i have upgraded the software? As i cant see a difference lol
Old 03-09-2009, 04:42 PM
Porkie
Porkie's Avatar
Originally Posted by Graceland
No
WRONG!
look on youtube mate
v easy to do!
I would give you a link but cant get on youtube at work. It only takes 2 mins to get ITV HD on your Sky HD box through the back door!
Old 03-09-2009, 04:43 PM
cossiestu
cossiestu's Avatar
You can get ITV HD, but when a colleage showed me how, it kinda fried my brain!!
...Should of written it down while he was going thru the menu... Sorry.
Old 03-09-2009, 04:46 PM
Porkie
Porkie's Avatar
LOOK ON YOUTUBE!
fuck me... I did it!!! that means ANYONE can!!!
cossiestu
cossiestu's Avatar
Its good if you have a on-going problem, but wont always be noticable normally. If you go into the menu you can see the software code, which may change after a forced download...
Old 03-09-2009, 04:56 PM
SteveT
SteveT's Avatar
So true, I've been noticing this for years.
It's one of those things that pisses me off - and I can't help but notice it, lol. What's the point of paying out for the latest high resolution TV set only to be feeding it a shitty low-bandwidth, highly compressed signal?
All this hype about HD digital TV, and they can't even afford the bandwidth for decent quality SD digital TV.
rant over lol
steve
Old 03-09-2009, 05:37 PM
pete mcrash
what a cunt.....just tried the itv hd thing and i havn't got the new epg set up......mine does everything but doesn't find the itvhd channel to save
Old 03-09-2009, 07:00 PM
Rhys
Rhys's Avatar
I tired the backup thingy when switchin of the box before and didnt make any difference to software! I will try again though when at home next.
Will also try ITV HD
Old 03-09-2009, 10:53 PM
cjwood555
cjwood555's Avatar
..........what makes it worse is that now half the country has sky+/hd, what's the point in all the bandwidth sapping xxx +1 channels??!!!!!!!
If there was a problem with HDCP you wouldn't be getting a picture. Borrow a component video cable and see if the problem goes away - component can transmit HD at up to 1080P and doesn't carry HDCP data.
Chris
AJC
08-10-2015 11:09 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: who's got sky HD.....old box IS better...why
