lambda sensor gurus....help
Old Aug 25, 2009 | 08:48 PM
rik-rs's Avatar
rik-rs
Default lambda sensor gurus....help
hi, i need a sensor for my exhaust...
basically i just got a new front downpipe cat, for my 306, i was gonna use the old lambda, but can i frig get the old one out..
so just been looking for one the same part number as is in the old pipe..
do i need the exact same one, or do you just buy for a car model cos ive seen one listed for my car but the end 3 number are not the same...
the one in my old pipe is number
0258 003 668, but what ive seen listed i think for my car
0258 003 717
thanks
Old Aug 25, 2009 | 08:52 PM
L7 KOS's Avatar
L7 KOS
you can buy a universal 2/3 or 4 wire sensor mate, just match the wires up, there about £25, or buy one with the correct plug for a lot more.
Old Aug 25, 2009 | 08:56 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
Buy a spurious one with the connector.
Seen loads of false readings from bodged connections either soldered or bullet connectors.
Old Aug 25, 2009 | 08:57 PM
rik-rs's Avatar
rik-rs
wow so i could get this
http://cgi.ebay.co.uk/Top-Quality-Ox...d=p3286.c0.m14
fuk paying 80 quid, if that`ll work
Old Aug 25, 2009 | 08:58 PM
st3v3's Avatar
st3v3
personally, i would buy the one with the same part number, the reason being is also not just the wires have to match up but the voltage has to be the same.
because you have different last three numbers it might be down to voltage.
rik-rs's Avatar
rik-rs
sorry to sound idiotic, but what is a spurious one
Old Aug 25, 2009 | 08:59 PM
L7 KOS's Avatar
L7 KOS
I have fit loads of intermotor universal lambdas using the supplied connectors with no issues at mot time, but thats only my experience
Old Aug 25, 2009 | 09:01 PM
L7 KOS's Avatar
L7 KOS
As long as it reads the usual 0.2 to 0.5v it will be fine. Ask your local supplier
Old Aug 26, 2009 | 02:43 PM
I used to work in a main dealer garage and we used to use the universal on most cars.Just cut the old plug off your old sensor and solder the wires together.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
