Decent Caliper Paint
Redumbdancy
Hi,
looking to give my Golf's standard red calipers a new lick of paint. What caliper paint gives the best finish and is long lasting? Are the Halfords kits any good?
Also is it worth while spraying a coat of laquer over the paint once its dried?
Cheers,
Agar
Cheers,
Agar
Team HOTHOT!
I used Carplan Engine Laquor - £6 a tub from Charlie Browns or whatever they are called - never had a problem with this stuff, heat resistant upto 150 degrees celcius for prolonged temperatures, quite a lot higher for spiked temperatures
Testing the future
2nd that. comes as a 2 part epoxy that you mix up. thoroughly clean calipers first as well.
i have used hammerite in the past and found it ok, although couldn't say long term.
red calipers are gay btw. imo calipers should be black
Redumbdancy
Anyway, is one pack of the Foliatech enough to do 4 calipers? It seems expensive compared to hammerite and smoothrite. However, ive used hammerite before and its flaked off after time
14000+ post superhero
if you check the small print on the backs of the tins hammerite has a higher temperature resistence than some of the specific high temerature paints.
prep them properly and it doesnt flake off.
rsguy
44
29-09-2015 03:29 PM
