Can a faulty caliper feel like a warped disc?
Cossiemodo
This is driving me mad, I must get my car on the road today, it's 4x4 Sapp Cos.
It felt like it had a warped front disc, juddering under braking together with a scratching sound, I changed the discs and pads, it's exactly the same! I did notice one of the old pads much more worn than the other on that side when I changed them.
Cossiemodo
Thanks for the reply mate, all of these have been replaced already. But I think I'm there now, I think it's one of the caliper pins siezing up. I've oiled it (without removing it) just oiled it and shunted it in and out a few times, I think this helped a bit. Tomorrow I'm going to dig out the right size allen key so I can take it out and have a good look at it, replace or lubricated or whatever, see how that does.
the dodgy caliper could heat up the disc/pad causing it to then have the judder, ut the caliper itself wouldnt cause it (that make any sense?)
theyre sliding calipers so its not uncommon, take it apart and get it cleaned up properly. pretty sure you can buy rebuild kits for these too if you dont want to buy a new caliper
Cossiemodo
its the caliper mate, im getting the same from the rear end drivers side on my 3 door, ive changed disc's and pads plus the compensator valve . prices for these are all over the place so i might also try a little oil etc
There is a few pairs on ebay for your car £160
07-10-2015 12:56 PM
