RS2000 MK6 Problem
Old Aug 17, 2009 | 08:37 PM
Less.'s Avatar
Less.
having a mid life crisis
Default RS2000 MK6 Problem
Earlier tonight woudlnt start,then wnet out and it started after a lot of turning over,and when trying to turn it over and start it made a funny high pitched noise,when started ran fine lights not dim,idled properly turned it off now nothing like battery flat,but put battery on charge and it says its charged?
Any ideas anyone
Old Aug 17, 2009 | 09:39 PM
Less.'s Avatar
Less.
Anyone any ideas
Old Aug 17, 2009 | 09:46 PM
666's Avatar
666
yes that is my head
starter moter may have stuck on when started and burned it self out, try bump starting it, if it starts its the starter, if not its one thing out the way
Old Aug 17, 2009 | 09:50 PM
Less.'s Avatar
Less.
Will try bump starting it thats my first thought or the alternator
Old Aug 17, 2009 | 09:58 PM
666's Avatar
666
yes that is my head
alternator wont stop it starting if the batterys ok (it only charges the battery)
Old Aug 17, 2009 | 10:03 PM
Less.'s Avatar
Less.
Yep your right soz very pissed off so brain not thinking right tonight thanks for your help,so that noise was probaly the starter motor sticking as you said
Bloody RS2000,s eat their starter motors lol
Old Aug 17, 2009 | 10:06 PM
666's Avatar
666
yes that is my head
all escorts do, mines ok buti still keep a second had one
Old Aug 17, 2009 | 10:10 PM
Less.'s Avatar
Less.
Well pmed someone breaking one and see if he got an alternator aswell just so I have one spare of those
Old Aug 17, 2009 | 10:17 PM
666's Avatar
666
yes that is my head
lol wise move, enjoy fitting
Old Aug 17, 2009 | 10:19 PM
Less.'s Avatar
Less.
Local freindly garage will do it for me,I am too short tempered to do that fit things
Old Aug 17, 2009 | 11:31 PM
Ellie's Avatar
Ellie
Get something with a long handle and hit the starter motor, makes it work.
Old Aug 17, 2009 | 11:43 PM
Less.'s Avatar
Less.
Taa Ellie wonder if trolly Jack handle will be any good,thknk will tart it up and follow you go Jap lol
Old Aug 18, 2009 | 12:10 AM
Ellie's Avatar
Ellie
Not a bad idea!!
Old Aug 18, 2009 | 12:15 AM
Less.'s Avatar
Less.
Not a bad idea!!
I do sometimes have the odd one
Old Aug 18, 2009 | 12:19 AM
wirralphil's Avatar
wirralphil
does it make a ticking sound when trying to tun over. you could try rocking the car in 1st gear if it's still engaged.
Old Aug 18, 2009 | 12:20 AM
Less.'s Avatar
Less.
No not a ticking noise was more of a high pitched whine
Old Aug 18, 2009 | 08:35 AM
Csm's Avatar
Csm
Sounds like starter motor for deffo
belt it with your trolly jack handle and get someone to turn the ignition over at same time
Old Aug 18, 2009 | 09:20 AM
Less.'s Avatar
Less.
Cahrged the battery and it started first time ran it for five mins,now the battery completely dead so looks like a duff battery or an alternator problem.
Weird started first turn of the key,shut it off then nothing bloody thing
Old Aug 19, 2009 | 07:47 AM
I would check the battery voltage when the engine is running to see if the alternator is working.
Old Aug 19, 2009 | 12:06 PM
Less.'s Avatar
Less.
Any idea what the voltage should be,the battery not go flat just not enough to restart the car,as charges up pretty quickly
Becka674
11
Oct 8, 2015 03:11 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
